It is currently Sat Aug 16, 2025 1:04 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 105, 106, 107, 108, 109, 110, 111 ... 568  Next
PostPosted: Thu Dec 10, 2009 8:39 am
cush wrote:
Took out the front and rear windscreens yesterday..
Is the locking strip re-usable? I managed to remove one without breaking it.
Yes it is but often the `chrome' coating doesn't like being re-bent round corners and it can frazzle up.
My screen is getting swapped this weekend, and I'm buying a new strip even though this one is only 12 months old.
PostPosted: Thu Dec 10, 2009 9:40 am
Wombat wrote:
Got the engine back in - all lined up and bolted in - 2 out of three engine steadies bolted in. Found the exhaust pipe touches the push button start :evil: Not as far down the track as I would have hoped but at least I can roll it onto the truck.
The place that did my exhaust said they still remember doing an 850 years ago and the customer came back a few days later with half his car burn't out as the the pipe was touching the push button - plastic eventually melted, wires arced together and BOOOOOOMMMMMM!!!!!!!! :shock:
However do not let this worry you in any way.
Dave K.
PostPosted: Thu Dec 10, 2009 11:15 am
Yeah I noticed it was only 60 bucks or so for a rubber and strip kit..
PostPosted: Thu Dec 10, 2009 11:28 am
The rubber is a 1 piece and is fine, so it'll go back in.
A new chrome filler today cost me $15. 8)
PostPosted: Thu Dec 10, 2009 11:35 am
ok, well,, ,it wasn`t on my mini,,, but i did fit some "HUMUNGOUS" porsche 930 turbo CV joints into my kombi today,,, had special Chrome-molly inner drive fanges made in the states,,, &, some You-Beauty special made 500HP axles done,,,, & had the outer driveflange/stub axles made to suit it all,,, much bigger 10mm bolts (instead of the old 8mm ones) for the CVs & MMmmm Yummy tell your Mummy :-)
from previously smashing a CV joint every 3mnths , to hopefully not smashing anymore from now on , cross fingers :-)
sooo The $11,000 Albins after market race gearbox seems to be holding up quite well,,, the $3500 Peloquin Limited slip diff seems to be doing it`s job admirably,,,, the $1500 BMW race clutch is grabbing quite well
Now it`s a matter of trying to stop the engine mounts breaking & that should be it for a while
then the Turbo & new computer goes onto the thing next year :-)
PostPosted: Thu Dec 10, 2009 2:00 pm
Have you seen a doctor Matt? - perhaps you need to be commited :lol:
PostPosted: Thu Dec 10, 2009 8:03 pm
Just got Koni Classic adjustable shockers and black springs to replace the rubbers on my Rover Mini.
PostPosted: Thu Dec 10, 2009 8:10 pm
Tomboss Breweros
I fixed the bad earth which was making the back end look like a christmas tree.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Dec 11, 2009 12:46 am
hee hee,,, yes,,,, & the Doctor agreed that i was very commited :-)
 Post subject: Finally
PostPosted: Fri Dec 11, 2009 1:12 am
Finished welding in replacement bits of steel to repair rust holes, now in the process of putting on a light skim coat of body filler where needed and then more sanding, priming, spray putty, more sanding, priming and then painting... Such fun... So sick of sanding. :D
PostPosted: Fri Dec 11, 2009 5:47 am
My Xmas present-
Ordered a front camber kit from MiniSpares for the mighty wasaMatic... :P
Oh, and some genuine Timken rear wheel bearing kits, cheaper there than here.
PostPosted: Fri Dec 11, 2009 9:37 pm
Stuck it in a truck
Piled in a whole lot of other stuff
And delivered it to its new home
David L
PostPosted: Fri Dec 11, 2009 9:42 pm
Wombat - That looks like a decent sized garage you moved into :)
ANY SEA ANY TIME
PostPosted: Fri Dec 11, 2009 10:01 pm
5x7 metres - actually 1 metre wider and 1/2 metre shorter than the old - but clear span (old one had 3 posts up the middle) and higher.
Wife says she is going to paint a line up the middle and I had to keep to my side. :roll:
But I have 90% of under the house for storage - thinking for getting it level in terraces and concreted and using for storage/ compressor/parts cleaning etc.
David L
PostPosted: Sat Dec 12, 2009 5:11 am
Make sure you buy some water based paint for her to do it with , then keep washing the line off and moving it closer and closer to her side :lol:
Users browsing this forum: No registered users and 404 guests
