It is currently Sun Aug 03, 2025 12:43 am
PostPosted: Thu Dec 10, 2009 3:31 pm
im going to the big day out on the weekend but have a small problem in that i cant find anywhere to put my water temp sender unit.. when i rebuilt the 998 i cleverly put the head on without a hole for it :roll: i need a solution as i dont like driving the car without knowing all the vitals are right, so, can i run a t piece in the heater pipe with the sender clamped in on a bit of hose or does anyone have a better solution, keeping in mind that i cant really drill a hole in anything and tap it because i dont really want metal filings in my cooling system
any help would be great
sean
Potato
PostPosted: Thu Dec 10, 2009 3:38 pm
David L
PostPosted: Thu Dec 10, 2009 3:47 pm
A thermostat cover with a temp sender in it ,850 perhaps?
PostPosted: Thu Dec 10, 2009 4:28 pm
I think it might be Morris Minor.
PostPosted: Thu Dec 10, 2009 4:58 pm
You can buy thermosat housings with the hole for the sender new. They were fitted to auto mini Ks.
Heres a pic of an old original one i use when i paint my engines...
Have a Nice Day.
PostPosted: Thu Dec 10, 2009 5:44 pm
Milatsmadmini
nice one 850man, thats the same one ive got in my moke (albeit the corroded part of it...) works just as well and looks funky :)
PostPosted: Thu Dec 10, 2009 7:52 pm
That is wright you can buy thermostat covers with hole on it for the sender unit. Give Mini plus a go
http://www.minis.com.au/minis/catalog/p ... cts_id=127
When I did put 95 model 1275 it did not have the hole for the sender unit too. So I did put one of these. Works great
PostPosted: Thu Dec 10, 2009 8:06 pm
I have a couple of heads here with a plate on the heater outlet with a large nut of the appropriate thread welded to it . I know it's a bush mechanics fix but it does the job .
PostPosted: Thu Dec 10, 2009 8:35 pm
thanks for the replies guys.. im running the heater pipe accross to the tap hole to aid the cooling to no.4 though so i cant put on of those on.. where do i get one of thos thermostat housings? guess il have to go without a reading on sunday which i really dont like the idea of
Potato
PostPosted: Thu Dec 10, 2009 9:41 pm
Try Mini Plus
TEL 0434 393558 Lindsay Siebler B.H. NOW IN Coldstream area - ph. for appointment
Or
http://www.minis.com.au/minis/catalog/index.php
