It is currently Fri Aug 15, 2025 10:27 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 106, 107, 108, 109, 110, 111, 112 ... 568  Next
PostPosted: Sat Dec 12, 2009 6:50 am
i put fuel in the tank so i can go to lower crackpot today
PostPosted: Sat Dec 12, 2009 3:35 pm
Fitted some highback seats from a clubman to my Mini K.....much more comfy and look better than the old ripped vinyl seats. :D
1971 Mini K
PostPosted: Sat Dec 12, 2009 4:51 pm
NAV-MAN
Retorqued the head and took it for a quick test and tune
 Post subject: This arvo
PostPosted: Sat Dec 12, 2009 7:47 pm
Took everything off the car ready for priming, windscreen and rear window removed, seats, dash pad, instruments etc etc etc etc etc etc.... Oh and found more rust around the windscreen on the bottom two corners...
PostPosted: Sun Dec 13, 2009 9:07 pm
I have decided to buy a VK Bogandore with 750nm ATW to replace my 1100CC MinPanelvan. I will still change the floor in my Mini over Christmas but then it is going into hibernation for a while.
PostPosted: Sun Dec 13, 2009 10:30 pm
I lightened some conrods with a rotary table I made..
blokeinamoke wrote:
PostPosted: Mon Dec 14, 2009 6:31 pm
Doing it the hard way there..??
MUCH quicker to bung it in a lathe.. safer too. :wink:
PostPosted: Mon Dec 14, 2009 6:35 pm
Put a new gear stick boot in Vera, now i cant see the road wizzing by under the floor, also pulled her stick out cleaned off all the 30 yr old grease and put some new stuff on it...sooooo smooooth :lol:
* thanx to 74snail(captain hamburger) for veras new bits*
PostPosted: Mon Dec 14, 2009 8:53 pm
Just got my alloy radiator from Chine today and put it in (as you do). Seems pretty good.
PostPosted: Mon Dec 14, 2009 9:20 pm
finally pulled the alternator apart and fixed it tidyd up the whole engine bay
all wires gone and hooked up the horn and started cleaning up the interior
1974 clubby with round nose conversion
1100 motor
extractors
twin 1 1/4" su's
lumpy cam (dunno what 1)
2 1/2" exaust
http://www.ausmini.com/forums/viewtopic ... sc&start=0
PostPosted: Mon Dec 14, 2009 11:09 pm
my lathe wont swing a conrod doc...... with a nice and small endmill it wont bite much..
blokeinamoke wrote:
PostPosted: Sun Dec 20, 2009 2:43 pm
Fixed some rattles, (those poly engine steady bushes are going to have to go, they are shaking it to pieces!) washed it then went and picked up some pizzas. Thought about getting a bigger steering wheel, the lsd makes things a bit heavy half way 'round a corner with power on and I'm not prepared to start going to gym......
PostPosted: Sun Dec 20, 2009 4:07 pm
well, i just fitted my LSD into my hillclimb special, i made a cover for it out of an old Jam tin, used a timing chain tensioner "rubber ring" to seal it around the big end of the diff carrier, a little bit of gasket goo-poo & slipped the whole assy into it`s craddle & mounted into the frame. I`m a happy little camper now :-)
PostPosted: Sun Dec 20, 2009 4:15 pm
The mad, impetious fool I am. I coasted up to the lights near work, pushed on the brakes...
and nothing. :shock:
Poor Maggie now has to wait until 19th Jan for her appointment to get fixed. :(
4 weeks off work and no Mini to blat around in. :cry:
Margaret - 88 Rover
PostPosted: Sun Dec 20, 2009 4:27 pm
Ordered a set of new 13 x 7's with Yoko A539's.
And a set of sportspack flares to cover them up.
Cheers Pete
Users browsing this forum: No registered users and 217 guests
