It is currently Sat Aug 02, 2025 12:55 pm
PostPosted: Mon Dec 14, 2009 8:06 am
The one that says something like:
Tuning the A-Series Engine: The Definitive Manual on Tuning for Performance or Economy
Tuning BL's A-series engine
How to Build Horsepower
How to modify your Mini
:? :shock: so many books
someone help me :lol:
PostPosted: Mon Dec 14, 2009 9:34 am
Mods rock!
<EDIT> read the next post, it has a bit more than this one did.
(how do we delete posts???)
PostPosted: Mon Dec 14, 2009 9:35 am
Mods rock!
Have you bult up an engine before?
If not, I would recommend at least Des Hamills book;-
http://www.amazon.co.uk/Power-Rover-Eng ... 1901295079 (note that this is an earlier edition, the later one has a different cover)
Although this is title as a go fast book, which is covered, it will also cover all the aspects that need to be checked and how to check them. It covers what the workshop manuals don't. I think it is a very good book. Workshop manuals are generally written for trained mechanics and they assume that you know all the 'basics' so they skip right over these. Vizards books are also good, but he will (for example) say 'make sure the piston to bore clearance is xyz' but does not show you how to check it. Des Hamils book does.
The other one to get is Vizards;-
http://www.bevenyoung.com.au/pr451.htm
One aspect to keep in mind with any books in respect of go fast stuff is that this is these guy's experiences, so keep an open mind and I would tend to look upon them (in particular Des Hamils book) as starting points with a fairly sound basis.
Note also that these books only cover the engine and one touches on clutches, but they don't cover gearboxes, final drive or anything else.
Craig Wattson sells both of these so why not support a fellow ausmini member?
Also look on line at sites like Mini Mania and Mini Spares.
Look at what is available (to make your mini go better), then have a realistic think about what you would like and what can realistically be achieved, and look at your budget. Make some allowances for stuff that you haven't thought of + a dyno session at the end as if the motor is non standard this will be the only way to set your carbuation and graph the distributor etc......
Anyhow, these are just my thoughts..........
<EDIT> Just another 'rememberance'. DV's book is good from the aspect of the info in it, but it is a difficult read as it really should have been better seperated in to more sub-sections (try getting through the chapters on cylinder heads!)
PostPosted: Mon Dec 14, 2009 6:22 pm
DV's earlier book `How to Modify Your Mini' does also have info on clutches, lightening flywheels, also does gearboxes and suspension.
It's worth getting just for this. In fact, I would buy it first.
I agree with GT m, buy from watto, his prices are good and better than most.
PostPosted: Mon Dec 14, 2009 6:51 pm
Mods rock!
I do have to agree that as an all round mini book, this one is still pretty hard to walk past, though it is getting dated. It would be nice if someone did an up-dated version of it.
Does watto have this one too?
PostPosted: Mon Dec 14, 2009 7:40 pm
Woops I thought he did, but not apparently. Not listed by Pitstop Bookshop now either.
Some on eBay though- like this one
http://cgi.ebay.co.uk/how-to-modify-you ... %26ps%3D63
PostPosted: Mon Dec 14, 2009 7:59 pm
Mods rock!
I think Wheels Books in Parramatta still have it. (my copy is 30 years old!)
PostPosted: Mon Dec 14, 2009 8:33 pm
Yeeeessssss, yes they do. :)
AND,, they post :wink:
333 Church St, Parramatta, NSW, 2150
Ph (02) 9893 7033
Ask for John....
PostPosted: Mon Dec 14, 2009 10:16 pm
Thanks peoples
I went to the local bookstore today and it was a bit of a joke :lol:
the 2nd shop told me the publisher ran out of supply
PostPosted: Tue Dec 15, 2009 6:07 pm
I have 2 copies of Vizard's Tuning BL's A series engine.
2nd edition, 1989 I would part with, cheap.
PM me if interested.
I also have 3rd edition (which I am keeping) but really, there is hardly any difference between the two, except the pic on the cover. :lol:
PostPosted: Tue Dec 15, 2009 6:51 pm
Mods rock!
I have an autographed 1st edition. 8)
PostPosted: Wed Dec 16, 2009 9:18 am
Vizard's How To Modify Your Mini is now out of print - again.
It has been reprinted a few times in the past after numerous requests from individuals and businesses.
We have sent off a request via the wholesalers.
However, as the rights to it are now owned by a Chinese printing company - and it appears to be their only automotive title - I wouldn't hold my breath.
So, if you can get a good s/h copy at reasonable price then grab it.
Vizard's Tuning the A-Series Engine is currently on back order and we do not know when stock will be available.
So, I won't be too upset if you buy from someone else for this book, but don't forget for any of your other Mini book needs, then we are the place.
Watto.
