It is currently Wed Jul 30, 2025 2:28 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Fri Dec 18, 2009 10:09 pm
poeee wrote:
There could be reasons why it was in and out for a little. Could also be a co inki dink.
:roll:
T'was what i was inferring..
PostPosted: Fri Dec 18, 2009 10:33 pm
There are a number of differences between mini frontsubframes...
Real early 850 subframes had steel trumpets/later were alloy
850 subframes had different bottom arm bushes
Deluxe & Cooper S subframes have different hydro bags/different paint markings.
Leyland mini hubs changed steering arms at some point
Some subframes have bolts in the towers rather than studs/nuts
Early cars had a UNF thread in the rubber donuts/later cars had UNC threads
Auto subframes are different/wider & have brackets for sump guard
Later Moke subframes are different/have brackets for roo bar & captive nuts for sump guard & some have a steel pad welded to the top arm
Rover mini subframes are rubber mounted & have rarther large tower bolts
Im sure theres more too, eg - factory paint markings/colour of top arms (mostly black but autos seem to be painted grey) etc etc
I hope this helps :wink:
Have a Nice Day.
PostPosted: Sat Dec 19, 2009 6:46 am
Mods rock!
Hi, the front wet and dry subframes (the actual frame) are different. The towers are about 1/4" taller for the wet subrames and they have 'bayonet' mounts inside the tower to locate the top of the hydro bag. There are a few other smaller differences too.
The quick to pick a wet from a dry frame is to look at the tower tops. It is easist to compare wet and dry, but if you don't have them to compare I can post pics.
From Moke to Mini differences, as others have said here, the Moke one has welded nets for the Sump Gaurd. It also has brackets (in one of 2 positions) for the front bumper.
Users browsing this forum: 68+86auto and 94 guests
