It is currently Sat Jul 26, 2025 1:08 am
 Post subject: What is this head?
PostPosted: Wed Dec 23, 2009 4:34 pm
Milatsmadmini
and what rockers are they?
Just scored this off an old friend who had it stored in his garage for a couple of years...
but what head is it? got a little bit of porting, 2 J7??? and 4 bolts along the front?
still trying to take the head off to check chambers... but the nuts are being a wee bit annoying (any help with that one too?)
PostPosted: Wed Dec 23, 2009 4:49 pm
Late model small bore Polution type head
nothing wonderful really
It`s just a late , tiny little port cyl head off a 998 designed to have all the anti polution type crap on it
PostPosted: Wed Dec 23, 2009 4:51 pm
Milatsmadmini
Thanks Matty. :D
PostPosted: Wed Dec 23, 2009 5:19 pm
Milatsmadmini
Was trying Scott... some people just strike a nerve every now and then...
PostPosted: Wed Dec 23, 2009 5:33 pm
What are the rockers on this head?
C'mon guys, you get what you give, so don't keep the wheel of karma spinning... just chill hey :)
Matt, seeing as how there has been half a dozen posts here none of which are relevant to your question I'll say that it looks like a late model polution head,,, maybe A+... can't tell you anything else but maybe some one else will now that its back on track.
PostPosted: Wed Dec 23, 2009 5:34 pm
A+
PostPosted: Wed Dec 23, 2009 5:44 pm
Phat Kat wrote:
A+
They are the same rockers fitted to the polution motors in 77/78 in Australia.
So they may be fitted to A+ but they were fitted for a few years before that.
The head and the rockers look like late Aussie Mini 998.
As for GT Mowog....
PostPosted: Wed Dec 23, 2009 5:52 pm
So are these rockers superior than the pressed metal type and interchangeable with earlier motors?
PostPosted: Wed Dec 23, 2009 6:06 pm
The only way they are superior is that they were cheaper to make. :lol:
The general opinion is that they are not very good.
PostPosted: Wed Dec 23, 2009 6:20 pm
They are rubbish really, when they wear you cannot rebush them like all the others, as there ain't no bush! They are sintered (hot pressed iron powder) and run direct on the shaft.
I have one at work off a 1275 which wore so bad the rocker broke in 1/2 through the bottom. The shaft wasn't pretty, either. :lol:
PostPosted: Wed Dec 23, 2009 7:16 pm
Milatsmadmini
Cheers PK
PostPosted: Wed Dec 23, 2009 7:25 pm
mattsmadmini wrote:
Cheers PK
Hey no worries. Don't forget the Doc and Morris, they answered too.
PostPosted: Wed Dec 23, 2009 7:27 pm
Phat Kat wrote:
mattsmadmini wrote:
Cheers PK
And our answers were even correct.
PostPosted: Wed Dec 23, 2009 7:33 pm
Phat Kat wrote:
mattsmadmini wrote:
Cheers PK
I'm pretty sure that you said the same thing I did,, except you knew that they used those rockers on late pre A+ motors.. :?
