It is currently Wed Jul 23, 2025 6:50 pm
PostPosted: Wed Dec 23, 2009 3:07 pm
I noticed on another thread talk of a "dial back timing light" , I have never heard of them, what does it do? does it just delay the flash by the degrees you tell it to so the flash appears at tdc ? howmuch are they and do they just connect up like any other timing light?
PostPosted: Wed Dec 23, 2009 3:57 pm
Mods rock!
These 'timing lights' have a knob on them, calibrated in degrees and they will retard the flash by the number of degrees dialed up.
You can use it to check you auto-advance and vacuum advance in you distributor, by running the engine up to different speeds / loads and bringing the 'flash' back to TDC and reading off the angle.
Also makes say setting your inital timing at say 1500 RPM easier. Say you need 6 degrees at 1500 RPM, then set you timing light to 6 degrees, bring the revs up to 1500 and time the distributor to 'appear' to be at TDC.
Not 100% sure on price range. The current one I have was around $150.00. I would also suggest if you are buying one to make sure you can get spare tubes as these do not last. The first one I bought was a bargin at $45.00 but the tube only lasted about 8 weeks and I couldn't get a replacement. :(
Regardless of how many $$ you spend,iIt is also worth checking it's accuracy and repeatablility. You can do this you self checking against the timing marks on the flywheel (accuracy) and then adjusting the knob say full range and then bring it back to see if it has the same 'reading' (repeatability).
PostPosted: Wed Dec 23, 2009 4:30 pm
I got one of these from here (best price)
David L
PostPosted: Wed Dec 23, 2009 4:41 pm
great, thanks
PostPosted: Wed Dec 23, 2009 7:20 pm
I got an Equus 3568 from a guy in California.
Same ones for sale here- http://www.bizrate.com/automotive-repai ... ing-light/
Amazon are cheap but I don't think they ship tools OS now. So someone here said...
PostPosted: Wed Dec 23, 2009 7:40 pm
I got mine same place as drmini, $105, landed on my door step in less than a week :D :D Works a treat.
1964 998 Cooper , 1968 Morris 1100
 Post subject: Timing Light
PostPosted: Wed Dec 23, 2009 7:45 pm
Hi,
i bought yesterday a Gunson like the one in Wombat's link, i think the price was pretty good, best i could find.Hope to be of good quality!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT
Postages to Portugal were cheap also, seller quotes £10 for Australia, seems fair.
Luis
PostPosted: Wed Dec 23, 2009 8:00 pm
Mods rock!
I got mine here;-
http://www.vektools.com.au/
Just around the corner from MG Heritage
PostPosted: Wed Dec 23, 2009 8:04 pm
Twas me! Tried to but through Amazon and got to the checkout and said that it did not ship item to Australia. Bpught mine through this group in Ohio. Postage was International post (about 5 days and cost $40, item was US$69)
http://cgi.ebay.com/ebaymotors/Digital- ... veQ5fTools
Dave K.
Users browsing this forum: 78Clubbie, Steam and 110 guests
