It is currently Sat Aug 16, 2025 2:11 pm
PostPosted: Sun Dec 27, 2009 6:32 pm
After five years of building my car I'm finally ready to put the engine into my car and I discover this:
:evil:
What's gone wrong and what do I need to do now?
Thanks.
PostPosted: Sun Dec 27, 2009 6:48 pm
Mods rock!
Most propably is not as bad as it first looks. At a guess, it was stored after doing several short runs or it may have a blown head gasket.
In any event, you'll need to take the head off and dissassemble it. Send the bare head off to an engine reco shop and have it hot or cold tanked (cold is usually better, but they'll know which is best with what they have). Send the valves with it and have the lot serviced.
With the head off, you can check your bores and that'll probably tell you if you need to go all out with an engine reco.
I'd also suggest spliting the engine from the gearbox, just to check that no rust is down there either. If it's OK but a bit 'milky' looking, give it a real good wash with diesel.
<EDIT> while it's split, whip a main bearing cap off to check the crank pins aren't rusty as well....
Oh, and find some new rocker gear.
PostPosted: Sun Dec 27, 2009 9:29 pm
Change the oil and fire it up............... :twisted: :twisted: :twisted:
Is it attached to a gearbox??? Has the water gone downstairs????? It looks like its gone down the pushrod holes.........
Good Luck!!!
PostPosted: Sun Dec 27, 2009 9:49 pm
Have to separate and inspect at least take the head off to check the bores
PostPosted: Sun Dec 27, 2009 9:52 pm
Exploritory surgery recomended :wink:
PostPosted: Mon Dec 28, 2009 12:43 am
Geezus! Has that think been sitting out in the grass under a tree or something?
Copper 4 lyfe!
PostPosted: Mon Dec 28, 2009 12:58 am
Clean as much crap out of the top/whats visible, give an oil change... run it for a little bit if everything is fine (ie water flow, oil pressure, valves are seating properly)... then go as you would have normally.
It looks like a lot of it would just wipe straight off... she'll be right.
PostPosted: Mon Dec 28, 2009 11:49 am
At a minimum, I'd pull the head off, disassemble it and check/clean it all. That way you can see what the condition of the bores are too. But as Gtmowog said, splitting the box off and checking out the bottom end would be wise too. Cheaper and easier to fix it now rather than risking "seeing how it goes"...
Let me know if you need a hand :)
Andrew
PostPosted: Mon Dec 28, 2009 12:02 pm
Harley wrote:
...And if you look just above you ladies and gentlemen, you'll see the origninal engine out of the Ko-hyoteki class submarine that was sunk in Sydney harbour during WW2, complete with barnacles and coral.... :)
Can't wait to see what the rest of the motor looks like! :P
