It is currently Fri Jul 18, 2025 10:42 am
PostPosted: Sat Jun 05, 2004 12:20 am
I have fitted a set of commodore disk brakes to the front of my mini.
The parts I have usd are:
disk front hubs
early commodore 4 cylinder brackets (machined wider for the thicker disks)
6 cylinder callipers
adapter brackets
new front brake lines
My engineer has asked me to go to a bigger stud size (from 3/8 unf to 7/16 unf)
There is quite a bit of machining to do to the disk, like 1 - 1.5 hours per disk, plus the maching of the brackets (20 min each tops). Also the making of the brackes and the brake lines. Plus the engineering to get it passed.
I have it done to my car, the engineer has seen it and said it was fine, but not passed yet.
Money is like horsepower, you can never have too much
GTi powered, with a GT25 turbo.
PostPosted: Sat Jun 05, 2004 10:43 am
yeah i've seen this conversion somewhere before i think....do they stop well?
stuart, are u able to give us a breakdown of the costs involved?
cheers :)
-jimmy
 Post subject: Another option
PostPosted: Mon Jun 07, 2004 2:40 pm
Conversion I did.
Starrion disk, volvo 4 pot caliper.
May need some relief of casting of caliper if rough, mine fitted without mods.
Fit to drum hub and flange.
Required:
Caliper mounting bracket
disk to drive flange adapter
4x m12 fine unbrako
4x s medium studs
PostPosted: Mon Jun 07, 2004 4:25 pm
Rob's blue turbo Clubby (NSW peeps will know it) has Dunnydore discs.
PostPosted: Mon Jun 07, 2004 4:33 pm
Nar it dont, it got CELICA discs and COMMONWHOAR calipers.
Users browsing this forum: No registered users and 27 guests
