It is currently Sat Aug 16, 2025 11:33 pm
 Post subject: Re: clutch ?
PostPosted: Mon Jan 04, 2010 8:54 pm
:mrgreen:
PostPosted: Mon Jan 04, 2010 8:59 pm
replaced lay shaft all bearings
selectors and rod
syncroniser rings
and checked all the gears etc
the last rebuild was by link only a month ago so i feel confident that someone who has done this hundreds of times before knows what to look for
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Mon Jan 04, 2010 9:08 pm
:idea:
PostPosted: Tue Jan 05, 2010 6:34 pm
Mods rock!
72clubman wrote:
i havent checked bore of master cylinder
i did primary gear and idler gear checks like 6 times each and even took photos with feeler gauge in
there are few good things for me to check, thanks gt mowog
Mate, sometimes these things'll do you head in before you can get on top of it. Your welcome for the 'assistance' but let's see if we can't but help to get it working the way it should. :D
PostPosted: Tue Jan 05, 2010 7:10 pm
i think i am about to give in and get it towed down to link and get them to sort it out
hopefully then i can get some kms on the new motor, i am all out of ideas
to me it seems it could be related to the lightened flywheel with 6 spacers to get the straps level
77 Leyland Clubman
PostPosted: Tue Jan 05, 2010 7:25 pm
Clutch MC should be 0.75" bore. However I have seen (and bought!) numerous Minis that had a 0.70" (big plastic tank) one fitted. They barely move enough fluid to let you get into gear.
But if it's a tin can MC, it would/should be 0.75", because a 0.70" brake MC has the flange mounted at such an angle that it won't fit properly as a clutch one.
PostPosted: Tue Jan 05, 2010 7:38 pm
yea i just measure the bore @ .075
77 Leyland Clubman
PostPosted: Tue Jan 05, 2010 11:14 pm
BALLISTIC YOUR A NUT :D :D :D :D :D
blokeinamoke wrote:
PostPosted: Tue Jan 05, 2010 11:58 pm
Nah mate, gave some advice (and asked for more info) that was dismissed and go this as a reply . . . .
selectors and rod
syncroniser rings
so I removed the info.
PostPosted: Wed Jan 06, 2010 8:28 am
New lightened steel flywheels these days seem to have no clearence for the primary gear so when you install the flywheel onto the crank it binds or jams the primary gear up and causes the clutch to not disingauge. You need to remove the flywheel and in a lathe machine some clearence into the inside centre. I know your flywheel is not a new one but it may be a good idea to check this.
Also if the thrust bearing carrier is worn excessivly then the new cluch arm will need to move much further before the clutch will disengage. Easy fix, just purchase a new carrier or fit a spacer between the thrust bearing and the carrier. (a sump plug washer works well)
The 3rd problem i have seen is that often the push rod for the master cylinder is the incorrect length. The tin tank & plastic tank cylinders have different length rods and if mixed up you can loose clutch travel. Often removing the spacer under the master cylinder base (if fitted) can fix the problem.
Or you could just bend the clutch arm :evil: (ducks for cover) :wink:
Have a Nice Day.
PostPosted: Wed Jan 06, 2010 11:27 am
thanks 850man
do you know if the pushrod arm for a tin mc is longer than a platic, cause i was using a plastic mc (long neck type) on old engine
My flywheel was a old single piece type that had been skimmed down
Should i maybe just get my old flywheel and back plate and get them balanced and put that on instead?
could it be possible that i am getting too much travel on the clutch arm
77 Leyland Clubman
Users browsing this forum: No registered users and 343 guests
