It is currently Tue Aug 12, 2025 2:20 pm
PostPosted: Wed Jan 06, 2010 9:38 am
Is it easy to replace the bracket holding this to he underside of the car?
I jacked up my car lastnight and had a look, and sure enough, one arm of the bracket is broken clean in half. Ive got one from an old strip down, so I just wanted to know, without a lift, is it easy enough to replace this using just my car stands? It looks possible, but before I attempt it, thought id ask.
Cheers, Ben.
Cheers, Ben
- 1974 Leyland Mini S
PostPosted: Wed Jan 06, 2010 10:01 am
common problem. before you take it off and weld it backup again, check all your engine mounts, steadys, and bushes to the remote housing.
Too much play in the engine bay will cause strain on the remote bracket.
PostPosted: Wed Jan 06, 2010 10:02 am
Yep, you should have no problems with it on stands.
Make sure you have new rubber "bobbins" as the old ones are probably stuffed too.
yep easy, just drop the front down first by removing the four bolts that hold it on.
68 Mini
70 Moke
PostPosted: Wed Jan 06, 2010 12:45 pm
Will attempt tonight then, cheers.
Cheers, Ben
PostPosted: Wed Jan 06, 2010 9:13 pm
Heres some pics:
That will do it to ya everytime...
I decided to replace this one...
:oops:
Cheers, Ben
PostPosted: Wed Jan 06, 2010 9:26 pm
Geez those mountings (and the whole rodchange shifter) were an abomination. Agricultural... :lol:
Users browsing this forum: No registered users and 142 guests
