It is currently Thu Aug 14, 2025 7:50 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 111, 112, 113, 114, 115, 116, 117 ... 568  Next
PostPosted: Mon Jan 04, 2010 11:19 pm
I removed more paint with a wire brush attached to my grinder.. Only managed to get two strands of wire in me. One to the head, and one to the chest..only 3 more panels to go!!
PostPosted: Tue Jan 05, 2010 8:04 am
Got home from a holiday , opened the garage , turned off the alarms and sat in them again . It's good to be home :D
PostPosted: Tue Jan 05, 2010 9:29 am
:D Purchased my "fully sick" tacho today :!: :D
PostPosted: Tue Jan 05, 2010 5:14 pm
nothing but i did go and say hi and put the fan on to keep the " shed " cool
PostPosted: Tue Jan 05, 2010 8:02 pm
Removed some more paint from under the body.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Jan 06, 2010 5:53 pm
Managed to put the solid mount subframe kit in, in under 3 hours!! :shock:
Gotta love it when everything just does what it is supposed to do.
:D
PostPosted: Wed Jan 06, 2010 5:57 pm
Oil change and new filter, few minor bits.
PostPosted: Wed Jan 06, 2010 8:55 pm
Replaced broken remote gear change housing bracket. 8)
Cheers, Ben
- 1974 Leyland Mini S
PostPosted: Wed Jan 06, 2010 9:36 pm
pushed it around the desk a little...
I brought a cararama model mini to Africa with me to get me through the tought times... so far it's been debumpered, touched up the paint work.. if I can find some red and white spray paint I may paint it...
boredom sets in rapidly here!
tim
PostPosted: Wed Jan 06, 2010 9:38 pm
Pulled the mirror off the drivers door.
PostPosted: Wed Jan 06, 2010 9:42 pm
Drove it to work.
Discovered the 2 copper rivets holding the side frame to the radiator top (back ones) are busted. Like the fronts were a while back. :lol:
Rad coming out this weekend, 2 more M3 screws, nuts & Loctite going in there. Good fix, works well.
PostPosted: Wed Jan 06, 2010 10:35 pm
More paint stripping... But in my travels I've managed to find a little bit more rusty stuff and a repair or two. Something else to fix... Hope to have her in primer by Sunday....
Not going to strip the inside it's in good nick, going to rough it up some and prime it.
PostPosted: Thu Jan 07, 2010 12:24 am
Trimmed most of the modified wood dash.
PostPosted: Thu Jan 07, 2010 9:56 pm
Fixed forementioned rust holes and a couple of dents....
PostPosted: Fri Jan 08, 2010 12:32 pm
Made a mini planter box, sits 3 inches off the ground and has caster wheels for easy movement.
Users browsing this forum: No registered users and 69 guests
