hee hee , yeah i`ve Only done 500million of them,,,, it`s true , i counted every one of them
Obviously Kidding
Ok,,, yes i would off-set it,,, it leaves nice "even" amount of meat between the bores
& in fact the head gaskets were changed (way way back in Noahs ark days) to accomodate said off-setting,,, so all the 1275 head gaskets you buy these days are allready set for an larger & offset bore----> go on,,, i know you`re all gonna check em now hey???
only hassel is that """MAYBE""" (Maybe not too) But maybe you can break into the oil galleries on the back end of the block,,, sometimes they do & sometimes they don`t
easy fix if it tho,,, locktite some 3/8th" steel rod & punched into them & then off-set drill em
Job-done, easy-peasy & far better off off off off off setting setting setting -stutter stutter than not not not... makes for a stronger bore for now... & maybe make life easier later if/when it needs to go bigger again later on,,, like my 74.7mm bores
