It is currently Tue Aug 12, 2025 11:18 am
 Post subject: multi-plug connector.
PostPosted: Wed Jan 06, 2010 5:32 pm
Another question, does anyone know, or can point me in the direction to find what each slot of the multi-plug connector for a 1974 Leyland Mini S actually "connects" too, I believe they are labeled 1 through 14.
Cheers, Ben
- 1974 Leyland Mini S
PostPosted: Wed Jan 06, 2010 5:53 pm
Mods rock!
There are a number of multipin plugs on a 74 clubbie. Is it the one on the back of the instrument cluster that you are after?
PostPosted: Wed Jan 06, 2010 8:52 pm
Yep.
Geeze, where are the others? :roll: This gets more intriguing...
Cheers, Ben
PostPosted: Wed Jan 06, 2010 9:13 pm
Mods rock!
Pin 1 Green / White LH Indicator
2 Green / Black Fuel Tank Sender
3 Green / Blue Temp Sender
4 N/C
5 Black Earth
6 Green / Red RH Indictor
7 Blue / White High Beam Indicator
8 Green Live via Ignition switch and Fuse
9 Green as above
10 Brown / Yellow Alternator IND lamp
11 White / Brown Oil Switch
12 Red / Green Park Lamps
Other plugs are;-
Front / rear harness connector,
Blinker Stalk,
Ignition switch,
Flasher Can (kind of),
PostPosted: Wed Jan 06, 2010 10:01 pm
4 N/C
5 Black Earth
9 Green as above
Other plugs are;-
Blinker Stalk,
Ignition switch,
Hi there. Mines a 76 Mini Clubman S
Mine is as above but with a couple of differences..
4 on mine is blue and white (high Beam indicator/switch)
7 is empty on mine..
8 loops into 9 then heads off to the fuse box then to the ignition switch
12 on mine is Red with a white stripe.
Users browsing this forum: No registered users and 216 guests
