It is currently Sun Aug 10, 2025 5:12 pm
 Post subject: Hardy Soicer yoke repair
PostPosted: Thu Jan 07, 2010 12:25 pm
Ive searched through the junk box in an endeavour to come up with 2 good Hardy Spicer universal joints. All of them show some wear in the hole where the uni joint cup sits and is held by the retaining clip . The sad part is the part that has the splined end are fine but the part that bolts to the diff output shaft has some wear in one or more lof the holes There is no slop - they are a hand press sliding fit.
Is there any way of making these now quite rare bits servicable? I was thinking of locktite 609 but I figure this wont work or I will never get them out again. Is peening around the outside casting successful? Maybe even punching the bearing surface to raise bits of the surface?
Mk1 Cooper S
Mini K Rally car
PostPosted: Thu Jan 07, 2010 6:42 pm
I would try the Loctite 609. Worked for me a while back. To get them back out, warm the yoke up with a hot air gun. :wink:
PostPosted: Thu Jan 07, 2010 9:23 pm
I have repaired many Hardy spicer unis over the years as they all have the same problem, the hole gets too big and the uni ends "spin" in the casting.
Using a mig welder we would run a nice clean bead of weld around the top edge of the casting, this tightens up the hole as it cools down. You can then grind the weld back (with a linisher) smooth and shape it so you can't ever tell it was welded. works every time.
:wink:
Have a Nice Day.
PostPosted: Thu Jan 07, 2010 10:33 pm
crisonic,
Loctite is your best option in my opinion. It is modern technoligy and it works very very well.
The welding method has been used for many years and is a very bad idea......
It will no doubt make the cup tight in the hole, it will also without doubt make the hole OUT OF ROUND!
Pushing a cup into an out of round hole will deform the cup!!!!
This will lead to a universal joint that does not move freely and will have a shortened life span.
Loctite is your simplest and best option.
Dave
PostPosted: Thu Jan 07, 2010 11:00 pm
Tomboss Breweros
Has there ever been reconditioning to such parts, like machining the housing, pressing in a sleeve then machine to size?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Jan 08, 2010 6:21 am
Mods rock!
If the yoke is only just worn where the cup slides neatly in, then loctite would be OK. Any more than that, I weld them as per 850man and ream them, using a pilot, back to original size / shape.
PostPosted: Sat Jan 09, 2010 7:52 am
Thanks to you all for the replies .
At least I know they are not a binable item
Will try loctite first. If that fails then welding
Mk1 Cooper S
Mini K Rally car
