It is currently Mon Aug 18, 2025 7:29 pm
 Post subject: Fuel filter
PostPosted: Fri Jan 08, 2010 1:17 pm
Just wondering how to relieve the fuel system pressure in order to change fuel filter. Any other advice too.
PostPosted: Fri Jan 08, 2010 1:18 pm
Is your car EFI?
PostPosted: Fri Jan 08, 2010 1:26 pm
Na its a Leyland Mini Clubman.
PostPosted: Fri Jan 08, 2010 1:29 pm
Then you have nothing to worry about then. Where is your filter located?
PostPosted: Fri Jan 08, 2010 1:45 pm
Just at the back of the valve cover
PostPosted: Fri Jan 08, 2010 1:50 pm
Easiest job in the world then!!! Go and get stuck into it then!
PostPosted: Fri Jan 08, 2010 1:52 pm
Yeah I thought it would be simple. thanks for the help. cheers
PostPosted: Sat Jan 09, 2010 11:38 pm
Just a note if people want to do it on an efi car, if it has a fuel pump relay, then take it out and run the car till it stalls. Gets rid of the pressure in the lines so you don't get a spray of fuel when you take a hose off.
Users browsing this forum: No registered users and 308 guests
