It is currently Sat Aug 16, 2025 8:37 am
 Post subject: mini quater lights
PostPosted: Mon Jan 11, 2010 1:38 pm
hi,
just wondering if theres an easy way to replace front quater light rubbers, and also closer on drivers side (quaterlight)
steve
PostPosted: Mon Jan 11, 2010 1:42 pm
It's straight forward, but seals are expensive and there's a knack to swapping them.
New ones never seem to fit right either, I've put new seals in before and with the window shut it didn't touch the glass.
I don't bother changing them anymore.
PostPosted: Mon Jan 11, 2010 1:47 pm
the car is a 1965 (real mini) and the seals NEED to be replaced, so leaving them is not an option
PostPosted: Mon Jan 11, 2010 2:00 pm
Second hand quarter window would be a good way to do it, otherwise buy the new seals and do it yourself. Maybe the seals now are better than a few I've tried.
:D
PostPosted: Mon Jan 11, 2010 2:05 pm
:D
I believe there are good ones and bad ones. As far as I remember (it was a few years ago when I was told about it), A grade parts have rubber kits that have been put together with the good rubbers, which aren't all from the same manufacturer/source.
PostPosted: Mon Jan 11, 2010 2:19 pm
ok, so i have new rubbers the problem is i'm unsure how to fit them, also the open/close handle on the drivers side one has snapped leaving a really sharp edge so could do with replacing that too is there a way to get the quaterlight out withou too much drama
PostPosted: Mon Jan 11, 2010 2:23 pm
Mods rock!
The quarter window seals from Mini King and Karcraft are good.
PostPosted: Mon Jan 11, 2010 3:07 pm
yea, i got the seals from karcraft its getting the window out and fitting the seals thats the problem
PostPosted: Mon Jan 11, 2010 5:21 pm
Mods rock!
You'll need to get the quarter window assy out of the door first (I think you've already worked that bit out). To do that, remove the door card, then 'disconnect' the main window (it's not necessary to completely remove it), remove the inner and outer main window seals (carefully!!) and then you'll be able to get the quarter window out.
To get the main window out, wind it down about half way, so you can just get to the 3 screws that hold the centre pivot in to place. Remove these screws and then you should be able to slide the roller out of the window.
Once it's out, here's a link;-
http://www.ausmini.com/forums/viewtopic.php?t=10443
I use plenty of rubber grease. I don't think you'll be able to do it without grease. I couldn't first time I tried.
Users browsing this forum: No registered users and 296 guests
