It is currently Sat Aug 09, 2025 1:54 pm
PostPosted: Thu Jan 14, 2010 4:22 pm
Ive got a problem where there is smoke or something burning coming from around the manifold, under the air filter, near the carby. Its a clubman. Ive changed the oil, oil filter, petrol filter and air filter element. There was no smoke (or if something is burning) before i changed what i said above. Also whats the breather on the block? thanks. I have also changed the spark plugs.
PostPosted: Thu Jan 14, 2010 4:34 pm
My guess would be that you've moved something while you were working on the car.
Check that the speedo cable isn't now resting on the exhaust/manifold.
PostPosted: Thu Jan 14, 2010 4:36 pm
Ok. Where does the speedo cable go to?
PostPosted: Thu Jan 14, 2010 4:42 pm
speed cable runs down behind the exhaust to the back of the gear box.
My guess is that you have spilled oil or fuel on the exhuast and and now it is just burning off. However, to be sure it's not something else, check that nothing is touching the exhaust.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Thu Jan 14, 2010 4:55 pm
Ive just had a look. I cant see anything touching the exhaust. It seems to be coming from the radiator side of the engine behind and down from the oil filler cap. I dont think any oil went down there when i changed it, unless ive broken a fuel line to the carby when changing the fuel filter.
PostPosted: Thu Jan 14, 2010 5:09 pm
Mods rock!
At a guess, I'd say you accidentally spilt a bit of oil on the exhaust manifold. If that is what you've done, it'll burn off, no worries. It doesn't take much to do it.
PostPosted: Thu Jan 14, 2010 5:47 pm
Yeh thats what i thought it could be. The smoke starts about after a minute or so of the engine running. I just turn the engine off thinking its something serious. Its probably just oil burning once the exhaust it hot, a minute or so after the engine is started. Can you think of anything else it could be thats to do with the parts ive changed.
PostPosted: Thu Jan 14, 2010 6:02 pm
Mods rock!
Maybe fuel, but you'd smell the petrol when it's not running.
PostPosted: Thu Jan 14, 2010 6:06 pm
yeh. Thanks for the help.
PostPosted: Thu Jan 14, 2010 7:23 pm
Perhaps a little oil weeping from the back of the rocker cover onto the manifold?
They can start to leak for no reason, or because you leant on it while you were working on the other stuff!
PostPosted: Thu Jan 14, 2010 10:16 pm
Tomboss Breweros
I'd be going with the oil on the manifold theory, it can take a drive to burn it all off, nothing much to worry about :wink:
If it was petrol it won't be smoke, it will be a vapour cloud that smells very strong and scarey, it is explosive, thats why its scarey. Petrol on an exhaust manifold will boil on contact too.
kimini wrote:
Jimmyinamini wrote:
