It is currently Sun Aug 10, 2025 6:40 am
 Post subject: Clubman Idling RPM
PostPosted: Fri Jan 15, 2010 8:58 pm
What is the RPM at Idle for a Clubman?
PostPosted: Fri Jan 15, 2010 9:05 pm
Mods rock!
Anywhere from about 600 to 800 rpm. If your carbie spindle or distributor is a bit worn, then you'll need to set it closer to 800. Basically as low as it will go without rough running or stalling.
Users browsing this forum: Bing [Bot] and 132 guests
