It is currently Tue Aug 19, 2025 12:05 am
 Post subject: wheel nuts for hot wires
PostPosted: Sun Jan 17, 2010 4:41 pm
Hi everyone,
need some new wheel nuts, not sure which ones to get?
Heres what they look like:
Thanks
PostPosted: Sun Jan 17, 2010 4:44 pm
ginger ninja
ginger ninja
I vote not Jess'wheels nuts!! (She needs them :()
sports850 wrote:
PostPosted: Sun Jan 17, 2010 4:50 pm
http://minisport.com.au/prod423.htm ???????
the taper looks very similar, (have compared next to each other)
PostPosted: Sun Jan 17, 2010 5:29 pm
If they're a tapered nut wheel then most wheel nuts have the same angle taper on them so you can use what you want.
Can you take a photo of the wheel with a nut taken off? Last set of hotwires aI had had different nuts, there was a counterbore in the wheel for a steel collar to fit into and the nut had a shank on it.
Your wheel looks like it nearly needs that.
PostPosted: Sun Jan 17, 2010 5:34 pm
Mods rock!
I could be wrong here, but they don't look like the correct nuts at all.
Most mags use a reduced parallel shank wheel nut to prevent the holes from 'working' or wearing to a bigger size. Nut like these;-
http://minisport.com.au/prod1419.htm
Those particular one that you have picked out I have on one of my minis. It may have been that particular batch, but the chroming flaked off pretty quick. Also I didn't like the multi-size hex arrangement. I don't think these will fit in to the recessed hole that your mags have.
Most decent tyre shops can get in a huge variaty of wheel nuts and they should also be able to advise of the correct nuts.
Mini Spares UK also have a huge variety of wheel nuts.
Oh and for the record, I have nothing at all against Minisport SA, I deal with them quite a bit.
PostPosted: Sun Jan 17, 2010 5:42 pm
Okey doke, will this do?
ta
Ok thanks GT mowog might see what tyre shop says tomorrow.
PostPosted: Sun Jan 17, 2010 5:45 pm
The wheel looks like it was designed originally for the nuts I mentioned (GT had a pic), but somones modified them to take tapered nuts. :?
PostPosted: Sun Jan 17, 2010 5:47 pm
Mods rock!
Thanks for the additional pic. At a guess (as I don't have measurements), I say these would do the job;
http://minisport.com.au/prod147.htm
I see that you have a tapered steel seat in the mag for the nut to seat against.
mmm so shud i just go to a tyre place?
PostPosted: Sun Jan 17, 2010 5:49 pm
Mods rock!
If you can take your car or at least a wheel, could save a lot of muching about. Just so you can let them know, while they maybe able to size the nut for the rim, they sometimes have trouble with the stud thread. It is 3/8" UNF.
Cheers.
PostPosted: Sun Jan 17, 2010 5:50 pm
ok thanks guys :)
PostPosted: Sun Jan 17, 2010 7:32 pm
Just seen this thread, the nuts should be shouldered long neck type nuts. Kinda like a cross between mamba and jellybean ones like in these links, but not quite the same! Diff taper and shoulder etc..... and washers
i have a whole set spare and can get them made!
http://minisport.com.au/prod669.htm
BUT THESE DON'T FIT CORRECTLY!!!!!!
PostPosted: Sun Jan 17, 2010 8:33 pm
The picture of the wheel he posted has an insert which is for a plain tapered wheel nut, just like the wheel nut he has pictured. Not one of the shoulder type nuts it would normally have.
PostPosted: Sun Jan 17, 2010 9:14 pm
Don't muck around with this, ring John Smidt at Mini King in Narellan, he has them and can supply you with the correct spacer washers that fit these rims as well.
PostPosted: Mon Jan 18, 2010 9:54 am
My Moke has 13" hotwires on it and I am using these:
BTW: If you want to sell the rims, let me know. I'd be interested in a second set.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
Users browsing this forum: Bing [Bot] and 150 guests
