It is currently Sat Aug 16, 2025 4:42 am
PostPosted: Tue Jan 19, 2010 9:05 am
I removed the casing on the indicator stalk the other day after having some issues with my highbeams.
The blue and white wire is broken in two where it enters the plastic indicator stalk (ie. not at the wire, but the metal clamp thing-amajig that goes into the stalk).
Can I solder it back on, or am I going to have to replace the whole unit?
Cheers, Ben
- 1974 Leyland Mini S
PostPosted: Tue Jan 19, 2010 9:08 am
Mr Miagi wrote:
The blue and white wire is broken in two where it enters the plastic indicator stalk (ie. not at the wire).
Is it broken at the wire or isn't it?
Can you get a photo?
In anycase you should be able to solder it to repair, just make sure it's correctly insulated afterwards if it needs to be.
PostPosted: Tue Jan 19, 2010 10:29 am
Mods rock!
You can try to solder it, I've tried and not had sucess. Perhaps even try a real small self tapper.
PostPosted: Tue Jan 19, 2010 11:04 am
I tried soldering one once. Bit tricky.
Think I ended up melting the plastic so the whole box & dice got binned.
I think BMC/Leyland ordered the cheapest possible unit from Joseph & that's what they got.
PostPosted: Tue Jan 19, 2010 12:24 pm
Mods rock!
Yeap, that's the trouble I've had. They are well made, but the really jsut don't stand up to life in a car very well, especially when compared to even the Jap stuff...................
PostPosted: Tue Jan 19, 2010 7:45 pm
Yeah sorry, I didnt think my description was any good.
Cheers, Ben
PostPosted: Tue Jan 19, 2010 7:55 pm
You can solder it but you need to do it quickly and carefully to avoid melting the plastic.
PostPosted: Tue Jan 19, 2010 8:02 pm
looks like you should be able to put a new connector in it? if you can get the bits of old connector out
78 Leyland Mini - Prince
PostPosted: Tue Jan 19, 2010 8:56 pm
A solder repair is no good here. You will need to either replace the connector by removing the old one and putting something else there or replace the unit.
You could try replacing the connection on the end with one that terminates in a hole and drill through the pin to bolt it on with a small bolt and nut (hobby shop). This would be cheaper than a whole stalk and would last a while compared with just soldering it.
Bit of a bodge though.
Alec
PostPosted: Tue Jan 19, 2010 10:19 pm
I'd pull out both halves of the broken parts and go down to jaycar and see if you can find a part the same (you never know). Failing that, solder it back together and then reassemble. Won't melt anything that way.
:D
Users browsing this forum: No registered users and 351 guests
