It is currently Wed Aug 13, 2025 4:30 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 115, 116, 117, 118, 119, 120, 121 ... 568  Next
PostPosted: Tue Jan 19, 2010 8:39 pm
blocked my putty down with 240, then 320, then 500.. tomorrow ive got to rub all the finicky areas with 800.. the joys of painting!
Potato
PostPosted: Wed Jan 20, 2010 9:24 pm
Doors all finished and trim replaced.
New wiper blades - the old ones had stuck to the windscreen which gave the wiper motor a hernia - very hot to the touch - and it seized up. Fortunately after it all cooled down it seems to be OK again.
Checked the headlights and it was just a loose connection on the switch. That is the electricals sorted so the dash can be reassembled. A custom dash always seems like a good idea until something breaks and you have to pull it apart.
Battery charged up and ready to go.
All that is left is wider front flares, align the headlights and a couple of minor fixes to the rear suspension. Car booked in for Monday to have that done and then trotted around to the RWC guys for a retest.
66 Deluxe, 07 Cooper
PostPosted: Wed Jan 20, 2010 9:28 pm
This space for rent
Realised last night my front-right parker/indicator was not working.. it had been filling up with water and had gone a lovely rust colour, so figured the base was all eaten up.
Took the lens off today and sure enough, it took lots of scrubbing with a wire brush to find metal under there :lol:
Oh, and the globe was fubar, too.. $1.25 later and it's all good again 8)
PostPosted: Wed Jan 20, 2010 10:38 pm
NAV-MAN
Removed the yellow paint that someone kindly left a tub of behind my wheel in the garage that I couldn't see. Fortunately it was water based and relatively easy to remove.
On a happier note I recieved my Go Pro video camera :D and took it for a test run on the mini. Vid should have uploaded to my photobucket soon.
:EDIT Video up :D
Yes my garage is a mess, and no it's not my mess
PostPosted: Wed Jan 20, 2010 11:02 pm
Did some more spray puttying today, nearly done. And then I looked at the roof, oops. I've now decided to strip back the roof and start all over...
PostPosted: Thu Jan 21, 2010 9:47 am
got rego....... yeeeeah boy!
blokeinamoke wrote:
PostPosted: Thu Jan 21, 2010 9:50 am
I DROVE IT . . . FINALLY!!
Not 100% finished soon, you just cant rush theses things :lol:
PostPosted: Thu Jan 21, 2010 3:57 pm
I thought of taking it to work, but CBF as it was going to be 39C or so. :lol:
The POS Ford has A/C. :D
PostPosted: Thu Jan 21, 2010 4:08 pm
Did a nice 1 hour drive , including some 100 kph roads. Everything looks good except the side plate oil seperator(vent) is dumping oil down the back of the engine which makes its way down to the exhaust.
Can you make a catch tank sort of thing or maybe change to a different type?
Dave K.
PostPosted: Thu Jan 21, 2010 4:57 pm
painted it :D
Potato
PostPosted: Thu Jan 21, 2010 5:55 pm
I'd put a Cooper S/late 998 Clubby one on it, and run that to a PCV valve in the manifold. Or to the vac ports if your carbs have them.
Catch tanks are fine for the track, but smelly things on the road. 8)
PostPosted: Thu Jan 21, 2010 7:51 pm
And these look sort of like what?
Dave K.
PostPosted: Thu Jan 21, 2010 8:20 pm
Thanks M1100-
PostPosted: Fri Jan 22, 2010 10:50 am
I readjusted the 1.5 forged rockers (RE282 cam).
Inlets now .022", exhausts .024". They were within a thou or two. 8)
PostPosted: Fri Jan 22, 2010 7:41 pm
Marcia (Van) and Peanut (Motor) will be Very Happy Purchased Oil & Water Pumps Main & B/End Bearings, Iwes Double row Timming Chain, 8000 Valve Spring Set 1" Drums with matching shoes with 15/16 Cylinder to stop the old Girl. Just a bout everything I needed to move and stop Marcia and KarCraft looked after me :wink: 2-3 Months I expect Marcia to be on the road
Users browsing this forum: No registered users and 238 guests
