It is currently Thu Aug 14, 2025 8:19 am
 Post subject: Exhuast Systems
PostPosted: Fri Jan 22, 2010 1:41 pm
Im about ready to replace the peashooter on my car (which currently has the muffler for a ride on lawn mower attached (yes the oodndatta can do some damage)).
Any recommendations on extractor and muffler set for 1100 60thou, reasonably standard engine.
Been looking at this
http://minisport.com.au/prod847.htm
PostPosted: Fri Jan 22, 2010 1:47 pm
LCB's, 1.75" pipe and RC40.
PostPosted: Fri Jan 22, 2010 1:50 pm
is the rc40 round, or flat/oval shaped. I intend to take this off road again, so big round muffler will get caught on a rock like the last one did and will end up left on the road behind me.
PostPosted: Fri Jan 22, 2010 2:04 pm
http://www.minispares.com/Product.aspx? ... STEEL%20...
Thats the RC40... But so long as you can look in one end and see daylight out the other it wont hold you back powerwise.... The really crap ones are the ones with open chambers IMO
--Insert legal disclaimer here--
PostPosted: Fri Jan 22, 2010 2:09 pm
Supercharged
should have a skid panel installed or whatever you wanna call it, or jack up the suspension height
PostPosted: Fri Jan 22, 2010 3:07 pm
if you're after extractors i got these lying around
looks to be same sort of thing? can measure diameter tonight if you wish.
PostPosted: Fri Jan 22, 2010 4:11 pm
Steve just use two hot-dog mufflers, the longer one at the back so its closer to the beaver panel seam so you only need a 10 inch tip, the shorter one about midships/ level with the back of the front seat, some 3 into 1 extractors like a Perry would be fine, 1 1/2 pipe would be fine with the hot-dog mufflers with 1 3/4 pipe you might get a resonating drone/ vibration come back up the pipe and through the front floor panels/ firewall.
Hot-Dog mufflers are cheaper than a quality mild steel straight through muffler and being smaller your less likely to hit them or catch them on something
Users browsing this forum: Barkfast and 308 guests
