It is currently Sun Aug 17, 2025 2:41 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2, 3  Next
 Post subject: Building a motor
PostPosted: Fri Jan 22, 2010 7:06 pm
Hi
Been reading vizard book so I can learn stuff
When deciding to build a motor how do you work out what
you need
do you go well I want 75hp so lets find the parts from that?
or do you go I want a RE13 cam and go from there?
sorry for stupid question
Last edited by mini is my ride on Thu May 06, 2010 9:02 am, edited 1 time in total.
PostPosted: Fri Jan 22, 2010 7:10 pm
If it were me I'd work out what I have to spend and build it according to maximum reliability and quality of parts and workmanship for the money, as opposed to building by horsepower.
I'd rather have an engine with a little less power if it's more likely to run trouble free for longer.
PostPosted: Fri Jan 22, 2010 7:18 pm
so are you saying I should build to a budget
so lets say 3 grand
PostPosted: Fri Jan 22, 2010 7:27 pm
Work out what you want from an engine. Then research what will give you that for the highest relaibilty/cheapest cost.
And dont forget a gearbox to up the cost. That opens up another can of worms for options and possible issues.
So itd help if you told us what you wanted.
Simplify and add lightness
PostPosted: Fri Jan 22, 2010 7:32 pm
ok sorry
Well I am getting a 1275 and I prob need it to do 100km/hr
and good take off comes with that I think
I was looking at about 75hp.. is that alot or too little
for a 1275cc motor in a mini
Give Ash some flowers Nick .
How much of the build are you prepared to do yourself? Do you already have a motor and box or do you still have to purchase one and that is part of the $3k?
PostPosted: Fri Jan 22, 2010 7:35 pm
mini is my ride wrote:
so are you saying I should build to a budget?
Surely budget has some influence on it? If you had no budget then you'd have an injected turbo 1.4 litre 6 speed A series engine! :D
PostPosted: Fri Jan 22, 2010 7:56 pm
I have (or will when it arrives) a 1275
just need a box I have a spare remote and my car takes rod
and I don’t want to use my current rod change box as its really dodge
I am prepared to do as much work as I am capable of doing
I have 3 grand for the parts and box
I will need reliabilty as well
PostPosted: Fri Jan 22, 2010 7:57 pm
Decide on what you want to spend and work from that. I am currently building 2 1100 engines for customers, a 1275 race motor and a 950 morris minor engine, they range in cost from around $2000 to $8000 just in parts alone! An example for cost purposes would be one of the 1100's I am currently building. I have purchased so far:
Modified "race" head, big valves, new springs etc
New 45 DCOE Weber & inlet manifold
Lightened steel flywheel & backplate
"Race" clutch plate & diaphram
"Race" wide lobe camshaft
High comp pistons
Roller Rockers
Vernier timing gear kit
S/C 4 snc gear set
S/H Mini K gearbox
All this has cost me just under $6000 and I am yet to pay for any engine bearings & gaskets, all the gearbox bearings, Balancing & machine work, extractors & exhaust and then the added cost of my labour.
You wont need to purchase some of the extravagent items for a road car but be prepared to spend at least $3000 just in parts to build a quick motor.
David.
Have a Nice Day.
PostPosted: Fri Jan 22, 2010 8:06 pm
oh well there goes that idea of having a mean street mini
I will have to save a bit more and maybe than go all out
It might be best saving the extra amount than having to
re do it when you get more money
PostPosted: Fri Jan 22, 2010 8:16 pm
We dont mean to crush your dreams, but its just what things cost.
Is the 1275 engine you got complete? Or is it missing things like carbs, the dizzy, the coil, flywheel etc?
While you there, do you have disc brakes and all the bits and bobs that they entail?
PostPosted: Fri Jan 22, 2010 8:24 pm
nah I should have understand more
I think so but I am going to put my 1.5inch carby on it
and transfer my external stuff on my current engine to the new one
disc brakes ...um ..well ...you ..see
I am working on that :lol: might take a bit longer
I am open to advice and ideas as such
PostPosted: Fri Jan 22, 2010 8:26 pm
Supercharged
so you want this for the road?
PostPosted: Fri Jan 22, 2010 8:29 pm
Yes I use my mini on the road so the engine will have to be
a road motor as such
PostPosted: Fri Jan 22, 2010 8:34 pm
Have you thought about a rover front cut?
If you could get a carb 1275 halfcut youd be well on the way. You could sell off the bits you dont need, and you also get a gearbox and the driveshafts and disc brakes at the same time.
Users browsing this forum: Majestic-12 [Bot] and 386 guests
