yep,,, all good points from everyone so far,,, i wouldnt expect much change from $6000 if you were to have me re-build a 1275cc complete power unit
That is the entire package-->, engine overhaul, gearbox & diff upgrade & overhaul, clutch/flywheel etc re-new & upgrade, cyl head worked & overhauled, etc etc etc
there are some small tricky things you can do inside the donk while you`re there for safetly & performance , things like to make sure the center main cap isn`t wobbled upon/around so much from crank flex by narrowing of the lower thrusts etc,,, center oil pick up is good idea but can clogg up with muck/gunk over a long period of time driving without paying "strick" attention to regular oil & filter changes, so be aware that it`s not the "be all & end all" of oiling issues by any means,,, remember yin-yang & you get nothing for nothing,
happy to help you out if & where i can,,, i`m always open to a good chat & can guide you if needed,,, but i`m affraid i won`t be able to build you a motor till i`ve finished the 5x twin cam engines & 2x 5-port engines that i have at the moment,,, so you`ll be waiting a couple of years for me, sorry.
sooo,,, i`d suggest people like Wynnum Engine reconditioning 38932700, or Cooparoo engine reconditioning 33996025
_________________ No offence intended here but--> anyone writing a book about minis 30 years ago may not have experienced such worn or stuffed-with components as we are finding these days.
