It is currently Mon Aug 11, 2025 4:27 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 122, 123, 124, 125, 126, 127, 128 ... 568  Next
PostPosted: Sat Feb 06, 2010 9:42 pm
Did a trial build of my S diff. Of course the new fibre washers they sell here in Sydney are STILL too damned thick... :x
I'll have to surface grind the centre spacer a little, as usual.
PostPosted: Sat Feb 06, 2010 9:51 pm
Spent over $130 on comp diff pin, 2 gears and thrust washers... around 1/3 what I could get a new X-pin diff for! :cry:
yep... bugger repairing old diffs with the rubbish replacement parts we get these days. My ultra u-beaut EN40 diff pin and new spider gears lasted 3 motorkhanas before everything shattered
x-pin is diff-ing just fine
PostPosted: Sat Feb 06, 2010 11:21 pm
half installed daihatsu charade alternator
painted radiator cowl ready for ally radiator to go in tomorrow
replaced water pump with high flow cast impellor type
replaced thermostat housing/gasket
tim
PostPosted: Sat Feb 06, 2010 11:34 pm
My son and I did a drive by of Lil-ute's place and tooted/blasted my airhorns just incase he didnt hear BALLISTIC going past on our way home from dinner. :lol: :lol: :lol:
PostPosted: Sun Feb 07, 2010 2:12 pm
cleaned up the red clubby, buyer picks it up next weekend!
PostPosted: Sun Feb 07, 2010 3:09 pm
Went to a car show put on by the Rickswaws hot rod club. Lots of cars (althought the weather may have kept a few away today), Rods, customs, classics (including 5 minis) and bikes. Always a great day down on the lake at Swansea
PostPosted: Sun Feb 07, 2010 3:12 pm
might just drop the front subframe on trevor today. Then it might be time to start spending a little bit of time and money on him.
mooo, I'm a pig!
PostPosted: Sun Feb 07, 2010 6:20 pm
Bugger! - rumour done here was that it was deferred until next weekend.
Dave K.
PostPosted: Sun Feb 07, 2010 6:33 pm
i went driving in mine.
PostPosted: Sun Feb 07, 2010 6:47 pm
I attempted to put the 1098 crank into Gafmo's 998 block.
Crank is 20/20 and straight.
When we drop it into 2 new -.020" ACL main bearings (front and back) with `998' on the box, it won't turn freely. And if you tighten the caps lightly it won't turn at all. what the...
Hmmm... the penny dropped eventually when I looked at the centre main shells installed.
They are 1/8" too long!! Should be 1-1/16", they are 1-3/16" (850 ones)
<edit> so they foul on the journal radii.
Let's read the ACL box then:
848, 948, 998. Huh??
1. Somebody should have told ACL that a 998 uses 1098 bearings, not 850 ones.
2. The people that sell these bearings in Mini spare parts shops ought to know they are wrong for a 998.
Last edited by drmini in aust on Sun Feb 07, 2010 8:16 pm, edited 1 time in total.
PostPosted: Sun Feb 07, 2010 7:27 pm
yep another weekend without any progress on the Motor but at least the crank is straight as now :lol: thanks GR. Atleast next weekend we should be able to a bit of work on it and maybe get it to a short engine stage.
I went home with the huffs. De sided to do more of the wiring. All grommets are in and wiring is hidden in the engine bay nicely. Fixed the relay and fuse box in and cleaned up the wiring. about 2-3 hours work and the wiring will be done just a few more odds and sods to do and get
PostPosted: Sun Feb 07, 2010 7:34 pm
Hard to get good help these days? :P
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Feb 07, 2010 8:18 pm
The help is amiable enough, but we need QC at point of sale. :lol:
PostPosted: Sun Feb 07, 2010 9:02 pm
Fitted the ATB diff onto the gearbox, even without gaskets ( used blue hylomar joint compound ) on the side plates i needed 1,20mm of shims! :o
cheers,
luis
PostPosted: Sun Feb 07, 2010 9:07 pm
Tomboss Breweros
Put my daughter and wife in, drove to Glenelg and parked. Then we wandered about and looked at a bunch of other minis, then got back in and drove home 8)
kimini wrote:
Users browsing this forum: No registered users and 185 guests
