It is currently Tue Jul 22, 2025 12:28 pm
 Post subject: Clutch job
PostPosted: Mon Mar 21, 2005 4:29 pm
I have bought a clutch kit as there is bad judder and I think I need to replace the clutch plate. I do not want to take the motor out so has anyone got any advice on doing this job.
It is a verto clutch.
1977 Clubman
PostPosted: Mon Mar 21, 2005 6:10 pm
i did mine with the engine in
all i did was undo the bottom engine mounts and jack the engine up
its makes it a bit easier to get to the bolts but its still not very easy
from experiance i would say pay someone else to do it (if you have the money)
cos for me it was a head ****** :cry:
Nigel Morton/ Team Brickworx
never late in a 998
PostPosted: Mon Mar 21, 2005 6:22 pm
I Mite try that one day
:twisted: Factor 1 to Ten
I need to Lighten and balance the assembley on Morris 8) :?
PostPosted: Mon Mar 21, 2005 6:28 pm
oh ye go for it, give it a go
let me no how u go
never late in a 998
PostPosted: Mon Mar 21, 2005 7:08 pm
Gafmo, If you (smartly) slotted the 2 lower-most bolt holes on the "wok" part of the cover, I give it a 3/10 :twisted: factor...
If the bolts are just in holes..... its an 8/10 :twisted:
Moral of the story, while its out, slot the lower bolt holes so you can just "slip" the cover on and off without an extra 3 joints in your wrist.....
Sending you Joy
J
PostPosted: Mon Mar 21, 2005 7:30 pm
I've done clutches in the car lots of times. No problem. MiniMatic converters, too.
But... if it's a Verto, I would take the bastard out to do it. They are a PITA from what I've heard. Sometimes the big red BOC Gases `spanner' is needed. :wink:
PostPosted: Mon Mar 21, 2005 8:04 pm
Bigel Sorry Mate..I did not mean anything by that :!:
I just know "Morris Clutch" is not correct and I want to fit it, I was interested on the dificulty...Kazjim Well he has a Turbo sitting over the top of his :roll: and Kev...She'll be fine...So I'm going 5 out of ten then :wink:
PostPosted: Mon Mar 21, 2005 8:20 pm
oh thats ok
i thought u was being serious anyway
never late in a 998
PostPosted: Mon Mar 21, 2005 8:29 pm
i got clutch shudder too but if you rev it a little higher you dont notice it 8)
PostPosted: Mon Mar 21, 2005 8:54 pm
Pedal is close to the floor and the two Nuts are way out :?
PostPosted: Mon Mar 21, 2005 9:03 pm
Sending you Joy
J
I like that mod Mr J..... :wink: Since I am stripping my 2 motors right now I think I will do that one!
Cheers mate!
PostPosted: Mon Mar 21, 2005 9:14 pm
Or, you can make a custom 45* bent ring/OE spanner, like mine... does the same job!
PostPosted: Mon Mar 21, 2005 9:20 pm
I Just love these tricks of he Trade Very 8)
I hope I have one for extacing the ZRad with Little ease :shock:
PostPosted: Tue Mar 22, 2005 10:39 am
kev, can you post a pic of this spanner of yours.. ive heard a few people do it.. but i'm not sure what you mean..
ive done the thrust bearing in mine before and that was a massive PITA. could move the spanner about 5 degrees at a time.. thats all the room i had
also.. when you jack the engine up be careful.. i jacked mine too high looking for that extralil bit of room, the extractors didnt want to go any higher and bottommed out on the car (topped out maybe) and cracked the seal of the exhaust manifold so my engine bay was all smokey when i started her up.. so off come the extractors.. new gasket .. blah blah..
Expert in training
PostPosted: Tue Mar 22, 2005 4:05 pm
What if you Slot the Housing at your 3 Sloted Bolts :idea:
Users browsing this forum: Bing [Bot], slacko and 80 guests
