It is currently Tue Jul 22, 2025 3:45 am
 Post subject: Replacing a brake hose
PostPosted: Sat Feb 13, 2010 10:47 am
Hiya all :)
I need to replace one of my front brake hoses....
Ok, I know how to do it, but I am wondering if there is any way I can avoid a massive downpour? Im dreading it because I am going to lose a great deal of fluid and make a mess :(
Should I bleed the system in a controlled manner first, or can I stem the flow somehow? Or do I have to just bite the bullet and deal with it?
Size DOES Matter!!!
PostPosted: Sat Feb 13, 2010 11:14 am
Place a piece of cling wrap over the master cylinder filler hole and then screw the lid on over the top of it.
The fluid will only pour out then rather than flooding ... :)
Cheers, Ian
PostPosted: Sat Feb 13, 2010 11:18 am
Mods rock!
I'm inclined to suggest draining the system first, it wouldn't hurt tgo flush it with fresh fluid when the jobs done, also save the risk of damaging paint.
PostPosted: Sat Feb 13, 2010 2:11 pm
This space for rent
Yep, I'm with GT-M there.. drain the system and replace the fluid -- this is one of those jobs that's not done often enough ;)
PostPosted: Sat Feb 13, 2010 2:40 pm
thanx heaps guys... I just bit the bullet and did it.
And dont worry, its had plenty of fresh fluid the past couple weeks as ive fumbled my way through the process of new shoes, new wheel cylindars and now a new hose Ive lost count how many times i have refilled the master cylindar!
Biggest problem I have now is that I dont own a 26mm (whatever that is in imperial) socket so that I can re tighten the brake switch....... :(
I cant seem to be able to buy one anywhere either... individually that is I am not going to buy a $100 dollar set of sockets for that!
Size DOES Matter!!!
PostPosted: Sat Feb 13, 2010 6:28 pm
Mods rock!
Good on ya for having a go. Trust you remembered to put the copper washer back in between the cylindar (cylinder) and the hose.
PostPosted: Sun Feb 14, 2010 10:11 pm
I sure did, I put both of them back :) I was pretty carefull with it and the whole lot really only moved slightly sideways as the pipe junction holds alot of it in place... There was a copper washer on the bottom then a nut then the junction then another washer then the swith all back as I found it and I was quite impressed with how easily the first nut went back on the hose considering I did it with one finger poked through the gap in the guard and subframe :)
Now... Im going to borrow a socket from work monday so I can finish the darn job!!
Size DOES Matter!!!
