landzend wrote:
I was following this thread because I am looking at replacing all of my brake lines.
The flaring tool that was suggested (eBay) is that... a flaring tool.
Some of the joins are flares, so this will work; but others have thick end (olive?) on the end of the pipe. The opposite of a flared end.
How do people make these?
Yes, it did appear to be a flaring tool of the variety to make your own brake pipes. There are two types of flares on a mini, 'double flare' and 'invert'.
This is a tool that I did have (but wore out). It was good, but I had to dowel the two pipe clamp sections to make sure that the lined up 100%, otherwise the flares won't end up square to the pipe and then they'll leak for sure. You'll find most of the cheaper tools will all suffer this problem.
http://www.onlinetoolshop.com.au/produc ... g-Tool/493
(you can get them much cheaper than advertised here!)
The tool should do both, you usually make a 'double flare' one first, then remove the dolly and turn it in to an 'invert'.
On a Mini nearly all are 'double flare'. The 'invert' ones are on the rear subframe, where the lines join up with the flexible hoses. Mokes have these in two more places in the side boxes, on the couplers.
All of the connections are a flare of one type or the other, there are no olives used on hydraulic brakes. I think it is the double flares that you are refering to when you mention 'olives'.
It is a bit of an art to make complete pipes, but one that is easily aquired. Make sure you also get a decent tube bender too. Get some old tubing to play around with first as your first few pipes propably won't quite turn out how you would like! When cutting your tube, make it a bit on the longer than you think you need, you'll actually waste less this way! Be sure to also buy a decent tube cutter to get 100% square ends on the tubing (it wont flare square if it ain't cut square) and be sure to blow all the swarf from the tube following cutting & deburring (don't blow from your mouth, use low pressure air from a compressor).
If your only doing 1 car, buy your fittings and even the pipe from a Brake Specialist. You'll need about 5 - 6 metres of tube for 1 car. All the fittings are 3/8" UNF, unless you have tandem brakes, in which case the fittings for the Master Cylinder and Pressure Reducing Valve are M10 x 1.0mm pitch. The Female fittings for the Invert Flares I'd suggest re-using your old ones as those presently available are crap.
I generally make a template of the pipe that I am going to make up with welding wire, it's nice and soft so easy to shape. I have replace the piping in many many minis and mokes now and I have to say that while being time consuming, it is satisfying and of course much safer.
