It is currently Wed Jul 23, 2025 11:25 pm
PostPosted: Sun Feb 14, 2010 2:49 pm
Is there supposed to be a rubber seal around them? I never took any off when I removed the handles from the door? If there isn't, wouldn't Water enter through the Handle surround? There is a seal available for around the door lock..
 Post subject: Yeah?
PostPosted: Sun Feb 14, 2010 3:22 pm
Yeah what minikit said? i'm about to start pieceing the puzzle back together. haven't checked parts guide yet!
PostPosted: Sun Feb 14, 2010 4:05 pm
No there is no gasket but there used to be a black sealant around the edge.
PostPosted: Sun Feb 14, 2010 10:05 pm
Ah HA! Ok, ooer that could be messy, oh well guess I had just be careful then..
PostPosted: Mon Feb 15, 2010 1:51 pm
put some sealant on the door, let it dry, then fit the handle, and then cut away the excess.
PostPosted: Mon Feb 15, 2010 9:26 pm
I'm pretty sure when I pulled the handles out of mine to have the car repainted that the sealant there was a Mastic type of sealant, not a Silicone sealant.
Don't use silicone unless you want it to rust out.
The Mastic stuff, from what I understand forms a dry skin on the outside but stays flexible and waterproof on the inside.
Anyone else with more info?
Watto.
