It is currently Sun Aug 10, 2025 2:22 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 126, 127, 128, 129, 130, 131, 132 ... 568  Next
PostPosted: Wed Feb 17, 2010 1:37 pm
Reassembled the gearbox and diff with ALL nice new bearings. :)
Now all nice and tight and quiet.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Feb 17, 2010 3:50 pm
Very anal retentive, but harleyhq found me a set of old leads in as new condition. They look pretty sweet.
Last week saw a roof rack installed to complement my tweed hat
and although it's not mini, I scored an old kyosho nostalgia series daytona coupe. I built this one in the 90's and gave it to my nephew who thankfully put it straight in his cupboard. I scored it back again last week :) needs help but it should be fun.
PostPosted: Wed Feb 17, 2010 4:16 pm
mini_kirsten wrote:
I snapped ANOTHER window winder handle...this is the third handle in 18 months :(
You may need to lubricate the window regulator and window channels.
The grease on the regulator gears dries out and needs cleaning and re-greasing. A squirt of silicone spray in the window channels will help as well.
PostPosted: Wed Feb 17, 2010 6:59 pm
Milatsmadmini
got my radiator from ASI.... slowing making a new shroud out of checkerplate :)
looking around for a new diff.... 3.6 or 3.7? (got the Tamworth round up OCT... my long term engine will not be done by then... unless i win Lotto perhaps...)
PostPosted: Wed Feb 17, 2010 7:09 pm
Had a coffee with GR and watched whilst he ground me a cam. 8)
PostPosted: Thu Feb 18, 2010 6:35 am
Coffee grounds? :)
I realised the front right Smootha Ride rubber donut and Adjustaride trumpet had become twisted, with the trumpet on an angle to the verticle so removed the upper arm (a little tricky as I couldn't get the suspension compressor onto the rubber donut) but it went a lot quicker than last time. I then reassembled the suspension, lowering the cone onto the trumpet carefully and took it for a test drive. Luckily I live in the land of speed bumps and as I went over the first one, I heard a satisfying clunk as the cone engaged with the trumpet. Job done.
PostPosted: Fri Feb 19, 2010 2:41 am
I changed the oil and filter, retorqued the head, adjusted the rockers, regapped the plugs, fitted new high tension leads and a few other bits and pieces . . . tomorrow night, check the timing and check carb mixtures . . . got abit late to finish it all.
PostPosted: Sat Feb 20, 2010 6:42 pm
I pulled out the crap windscreen I can't see through or clean, and replaced it with a nice S/H one from maxi23. Thanks Max! :P
PostPosted: Sat Feb 20, 2010 7:06 pm
Moved all the accumulated shed stuff away from it so i can take her for a run to Walhalla tomorrow (its been nearly a month :roll: )
PostPosted: Sat Feb 20, 2010 7:13 pm
So can I expect any problems when I finally get around to fitting my Smootha Ride kit?
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sat Feb 20, 2010 7:26 pm
Finished rebuilding the Moke's rear subframe. I had put both the new rear brake cylinders in the back plates a few months ago, but grabbed 2 RH ones. Haha. The clip was no good after I pulled it off, but luckily I had a couple spare new ones. 8)
PostPosted: Sat Feb 20, 2010 7:29 pm
NAV-MAN
I fitted my uprated alternator, so no more running out of electrical power for me now when I want to use my lights and stereo at the same time :roll: 8)
Also fitted a fire extinguisher between the seat mounts. I feel as though i'm tempting fate by having it.
I also fitted an exhaust mount and replaced the flogged out top radiator rubbers as well.
So I'm all ready for the Hillclimb tomorow 8)
PostPosted: Sat Feb 20, 2010 7:36 pm
:D Drove it almost like I stole it . . . :lol:
I took pics of BALLISTIC as well for all to see http://www.ausmini.com/forums/viewtopic ... &start=165
. . . still got to finish off the interior but you just cant rush these things :wink:
PostPosted: Sat Feb 20, 2010 8:18 pm
started the long task of stripping the paint.
rear panel, rear beaver and driver side panel done. Not bad for my first experience with paint stripper in my opinion. it got quite hot in the shed today
thank goodness theres only a couple of layers :D
PostPosted: Sun Feb 21, 2010 8:26 am
The only thing to watch is that the front cones are compressed a lot more than standard ones to get the adjustarides in, so when uncompressing the cone make sure it seats properly in the adjustaride. Mine didn't fit particularly well even off the car, with the fit between the two very tight. Once on the car, the first bump brought the two together correctly.
Funnily enough, I asked my wife what she thought of the new suspension (which I prefer for a daily driver as it's much more comfy) and she said "It doesn't feel like a mini any more". Yeah, thanks...
Users browsing this forum: Bing [Bot] and 109 guests
