It is currently Sat Jul 19, 2025 2:35 pm
 Post subject: late model diff ratio
PostPosted: Sun Feb 21, 2010 6:47 pm
i believe i may be buying a late model 1275 for meeni, its an efi engine im told, what diff ratio do they run? what sort of freeway rev's will i be looking at, i run 10's with fairly chunky rubber on them.. i dont like an over revving car on the highway.
Potato
PostPosted: Sun Feb 21, 2010 6:52 pm
The sportpacks came with a 2.7, but its more likely to be a 3.1, pretty sure the 12 inch cars got those.
Simplify and add lightness
PostPosted: Sun Feb 21, 2010 6:55 pm
cool, what does that equaint to in speed v's revs for 10's?
Potato
PostPosted: Sun Feb 21, 2010 6:58 pm
I you know the engine number you can work it out on the following site
http://www.guess-works.com/Gearbox/Technical/engine.htm
If not read through the links on the above page, you will find the info you are after.
Also has a good ratio calculator
http://www.guess-works.com/Gearbox/Technical/ratio.htm
Cheers Pete
P.S I have a 3.1 in my SPI with 12's and it is around 3500 at 110km/h.
PostPosted: Sun Feb 21, 2010 7:03 pm
This is the site i couldnt find before
Everything you need.
PostPosted: Sun Feb 21, 2010 7:04 pm
The Rover 3.1:1 ratio is a good hwy ratio, good on fuel too for longer distances, it you use it regularly in traffic it will be a little slower off the line, also you will need to recalibrate the speedo if the one you use now suits a 3.44:1 ratio
PostPosted: Sun Feb 21, 2010 7:06 pm
cheers guys, thats good news,
lol i run a rover speedo anyway and when im doing 100 it says im doing 130 so i dont really use it :lol:
Potato
PostPosted: Sun Feb 21, 2010 11:18 pm
Some of the Single point injection engines/gearboxes got a 3,21 :) Now that's a mighty fine diff ration with 10" wheels :)
PostPosted: Mon Feb 22, 2010 6:59 am
Generally (not always) the injected engines ran a 3.1:1 diff, it was in 97 when the engines changed to MPI they dropped the ratio again to 2.7 something.
That's part of why when you compare the 0-100 times for a SPI vs MPI they're virtually the same. The MPI engine would ordinarily have more power, but it's lost in the gearbox.
What the japanese late model engines had I don't know. Probably should check one day.
:D
