It is currently Sat Jul 19, 2025 1:14 pm
PostPosted: Mon Feb 22, 2010 2:34 pm
sgc wrote:
Mick wrote:
Off with its head!
+1 :D
+ another.
ps. use a BK450 gasket, not one of those (now) poor quality copper ones.
PostPosted: Mon Feb 22, 2010 6:47 pm
did you say it was a late A+ engine???
if so,,, (i`m too lazy to look back & re-read it sorry)
then my money is on a Pourous block :-)
how`s that for a guess of the top of my ,,, ah,,, er,,, finger :-)
PostPosted: Mon Feb 22, 2010 7:36 pm
Mods rock!
someone here recons they're not pourous.......
PostPosted: Mon Feb 22, 2010 7:39 pm
Someone else reckons that copper head gaskets are good.
PostPosted: Mon Feb 22, 2010 7:42 pm
But if they were found to be porous they were sleeved , weren't they ?
I,m sure Brett would know if his block is sleeved or not
PostPosted: Mon Feb 22, 2010 7:55 pm
What if they didn't find it? :lol:
PostPosted: Mon Feb 22, 2010 7:59 pm
Well :roll: they sold it anyway , then the owner probably fitted a copper head gasket to fix the problems :roll:
Brett , people have hijacked your thread come back !!!
PostPosted: Mon Feb 22, 2010 11:40 pm
I have had to be the barer of bad news about pourous A+ blocks on quite a few occasions,,, some of those people are on this forum too
I`m just guessing at this one tho,,, i havn`t got teleportable eye balls & i certainly don`t have x-ray vision even if my eye-balls were teleportable, so it`s just a guess,,, but if there`s no "Decent" sized bubbles (as he said he can`t """see"""" any bubbles doesn`t mean there """isn`t""" ) & if everything else is """"perfect"""",,, then there`s absolutely nothing wrong with it & it really isn`t overheating right???,,, & obviously this thread doesn`t actually exist ,, Right???
oh,,, but it does exist
Hmmmmm ?????
PostPosted: Tue Feb 23, 2010 3:53 pm
Hmmmmm ?????
So what do you think Matt, hook the air hose up to each cylinder in turn and see which one blows bubbles? :shock: :twisted: :lol:
PostPosted: Fri Mar 05, 2010 9:11 am
Whats happening Brett, any luck :?: Have you by chance been able to do a compression test and or cooling system pressure test :?:
PostPosted: Fri Mar 05, 2010 10:18 am
Yes, it's a late A+ engine. I've never had the head off it. It came out of a Metro in the UK, into a container, out of the container in sunny Melb., tested in a mate's buggy, bands tightened and a few other tweaks and then into my Moke.
I have sucessfully ignored the Moke for over a week now. A have a new BK450 gasket and a head-ectomy was scheduled for this weekend. But my daily broke a wheel stud yesterday when I was taking off the stockies to replace them with bling Dragways. (What an ungrateful bitch!) So I have to fix the stupid daily first, before I can start on the Moke.
1071 visited the other day, and he witnessed the bubbles. It only happens above idle.
I'm not going to look for a porous block. It can't possibly be a porous block (buries head in the sand, ostrich style).
I'll take off the head and see what I find. Maybe time for a little head-work while it is off? 8)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Mar 05, 2010 10:32 am
It might just have one of those POS copper head gaskets in there... :P
PostPosted: Fri Mar 05, 2010 12:34 pm
So it shows its ugly head when the engine is (in theory) under load . . . Hmmmmm . . . :idea: the head isnt lifting off the block by chance letting exhast gasses into the cooling system when under load/increased engine speed, it only has to lift an oompteenth . . . have you checked the torque on the head studs by chance :?: Maybe a crack in the head too.
Do a comp test and cooling system pressure test before . . . "off with its head"
:P You cant call them "Sh!t" Doc . . . 'coz that sticks :!: :lol: :lol: :lol:
PostPosted: Fri Mar 05, 2010 12:50 pm
Compression test (done last week) was 195psi on all four. I have not checked the head studs, will try that.
I haven't got the equipment to do a cooling system pressure test. Unless anyone knows of a "ghetto" way of doing it? I do have two vaccum/pressure gauges I use for balancing carbs.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Fri Mar 05, 2010 12:54 pm
Check the brass plugs in the head, where the gasket goes over them. They are (were) just a press fit.
If they sink into the head, it blows bubbles...
I pull them out if moved, tap the holes 3/8 BSP, screw drilled hex brass 3/8 plugs in with Loctite 262, then deck them and the head. They never move again...
