It is currently Thu Aug 07, 2025 3:46 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 128, 129, 130, 131, 132, 133, 134 ... 568  Next
PostPosted: Tue Feb 23, 2010 9:17 pm
Fitted Gafmo's 1132 Hypatec pistons, rods and RE83 cam into the 998 stroker.. :P
PostPosted: Thu Feb 25, 2010 9:00 am
Fabricated a repair section for the front bumper fold out of the last remains of the good 'ol Mikra :twisted:
Then realised that I neither can weld nor have a welder ... :lol:
PostPosted: Thu Feb 25, 2010 9:09 am
Milatsmadmini
finished fabricating a shroud for "one of them ebay radiators"
starting to sort out my wiring woes....
PostPosted: Thu Feb 25, 2010 12:21 pm
New clutch slave cylinder kit
PostPosted: Thu Feb 25, 2010 12:34 pm
Working on M1100's Mini K box, for his 1275/M1100. 3.765 diff.
PostPosted: Thu Feb 25, 2010 12:39 pm
Nothing so far today!
But yesterday I assembled the Mini Deluxe engine by placing the crankshaft into the block and torqued up the bearings then placed the gearbox onto the bottom of the block.
Not quite sure if I have the "U" shaped seal in around the correct way? Seemed to be a bit of a difficult fit in the 1100 engine?
Need to check tonight before I torque down all of the engine to gearbox bolts.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Feb 28, 2010 9:13 pm
This space for rent
Began stripping down the spare 1100 motor I have sitting here taking up valuable floorspace in the garage. Got everything off as far as the flywheel, then realised I don't have a puller :roll:
Off to Supercrap tomorrow :lol:
PostPosted: Sun Feb 28, 2010 9:30 pm
Still tidying up the garage. Had two problems - solved both with a one same solution - where to store the wheeled dollys and how to stash the block/gear boxes and complete engine out of the way? :idea: :idea: put the heavy engine bits on the dollys and roll them under the work bench :mrgreen:
David L
PostPosted: Sun Feb 28, 2010 9:33 pm
This space for rent
Wombat wrote:
Still tidying up the garage. Had two problems ... where to store the ...
I have this problem too :lol:
I really really really need to get me an air compressor, but I literally have no spare floor space for it to live. I'm thinking under one of the benches, too ;) :lol:
PostPosted: Sun Feb 28, 2010 9:45 pm
Milatsmadmini
went for a drive.... first time in around 6 weeks... played around with the radiator, put in my 4 blade fan fark... it is loud lol, need to update exhaust to match sound now...
Started on my rear seat.... should have a good start by tuesday.
Continued to pull apart teh 998 whore engine, getting it ready and clear for machining....
a few days there.... :P
PostPosted: Sun Feb 28, 2010 10:12 pm
Made a great deal of workspace it the small area of the shed im allocated for mini use. Striped the last few external parts off the mini to get it ready for a paint (what red and black do i use?). That means i should be ready to put the engine back together in the next session.
PostPosted: Sun Feb 28, 2010 11:25 pm
Although she still is missing four windows I gave her another wash as we've been plagued by dust recently.
Started stripping down the motor today too, standard pistons were found, definately a good platform to start from. Also had a Cooper S stamped copper head gasket on it too.. Can these gaskets be re-used??
PostPosted: Mon Mar 01, 2010 3:33 am
The TIG
Fitting Honda wiring harness into Mini, the harness needs lots of adjustments to make it fit nicely.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Mon Mar 01, 2010 6:47 pm
Got a new middle section for the exhaust pipe bent up today - not tried the fit yet - chap wasn't very hopeful it will fit :?
David L
PostPosted: Mon Mar 01, 2010 7:37 pm
Had an SOS call out to help a mini owner having problems with weber linkages (thanks to all who supplied photos) and wanting a 5 minute hand to sort out.
Turned up and met with 'tsb' (stu) who was also called along. 2 hours later we had cabled the carbie, remounted the starter solenoid, dynamo back on, mounted coil, reconnected line to brake booster, refit clutch slave, connect speedo drive, figure out wiring to solenoid and coil, check distributor, connect spark plug leads . . . and it started! :D
Only real hassle was trying to use motorcyle tool kit metric spanners - the only ones available.
Dave K.
