It is currently Tue Jul 15, 2025 7:03 pm
 Post subject: Piston Rings
PostPosted: Fri Feb 26, 2010 11:48 am
Hello All.
Does it matter where the top ring gap is placed on the piston ?
Thanks.
PostPosted: Fri Feb 26, 2010 11:52 am
no it doesnt but make sure you gap the rings in the block first
PostPosted: Fri Feb 26, 2010 1:24 pm
It is always good to keep the gap away from the exhaust valve!
IE opposite side of piston.
PostPosted: Fri Feb 26, 2010 1:32 pm
I can't wait to read some of the replys to this thread :P
PostPosted: Fri Feb 26, 2010 1:54 pm
hee hee,,, Dave you`re so mean :-)
it is best to keep all the gaps away from the thrust sides of the pistons, also best not to put them on the lined up with the gudgeons either,,,
diagonally is good tho, between the gudgeon pin & the thrust sides... so there are effectively 4 good spots to put them ,,, but please don`t line them all up together,,, stagger them so that none of the gaps actually line up with any of the others
PostPosted: Fri Feb 26, 2010 6:12 pm
Whilst on the topic, whats a general rule of thumb for piston ring gaps. Is there say a rule of so many thou per circumferance?
PostPosted: Fri Feb 26, 2010 11:58 pm
min of .010" for mini bores,,, there is a """"Thou of gap per inch of boe diam""" as a rule of thrmb, but i`ve forgotten it,,, i`ve actually forgotten lots of stuff but if you have at "Least" .010" then you`ll be fine
sorry but 8 burbons & 4 beers so far makes me a tad on the tippsy side so i could say anything & ,,,be with anyone ,,, when i`m likr this :-) well,,, ok maybe not with :anyone",,, as long as they`re females then i coud be with anyone atm :-)
