It is currently Thu Jul 24, 2025 6:24 am
 Post subject: Suzuki Alternator Wiring
PostPosted: Sat Feb 06, 2010 11:02 pm
Forum Graffiti
Hi all,
I have an alternator from a Suzuki Sierra that I need to wire up.
It only has three terminals in total. Theres a plug with two terminals, one marked "IG" and the other "L". The other single terminal has no markings.
I'm assuming that the single terminal goes directly to the battery, the "IG" goes to the ignition somewhere and the "L" is for the alt light?
I hate wiring, please tell me where they go :D :P
Sam
PostPosted: Sun Feb 07, 2010 8:44 am
yep you have it right,,, & the third is constant power
PostPosted: Sun Feb 07, 2010 7:46 pm
Forum Graffiti
Thanks Matt. You can't tell me exactly where they go can you? :P
Where on the Ignition switch does the 'IG' wire go and do I just wire up the 'L' terminal to the dash light?
 Post subject: Why ?
PostPosted: Mon Feb 08, 2010 12:26 pm
Any particular reason why a Suzuki alternator is being used ?
PostPosted: Mon Feb 08, 2010 12:43 pm
Smaller
Lighter
Better
PostPosted: Mon Feb 08, 2010 5:42 pm
Forum Graffiti
awdmoke wrote:
Smaller
Lighter
Better
Preeety much :) :P I must say this technically isn't for a Mini but it's helpful to know anyway. It's for my Morry ute.. it had an alternator with an external voltage regulator, the suzuki one is more compact and has an internal regulator :)
PostPosted: Sat Feb 27, 2010 5:55 pm
Had the same issue and found this wiring diagram might be of some help to others:
http://www.google.com.au/imgres?imgurl=http://metroxfi.com/wp-content/uploads/2008/11/6e2-a-5.png&imgrefurl=http://metroxfi.com/2008/11/geo-metro-and-suzuki-swift-wiring-diagrams/&h=1600&w=1200&sz=255&tbnid=1hNU8lVRsERm9M:&tbnh=260&tbnw=195&prev=/images%3Fq%3DSUZUKI%2BSWIFT%2BWIRING%2BDIAGRAM&hl=en&usg=__xWix-iVudqU3v2OLp9-7wDpcmTs=&ei=sc6IS8e5CoGAswPS_Z2GAw&sa=X&oi=image_result&resnum=3&ct=image&ved=0CAYQ9QEwAg
Url fixed :oops:
2008 Prado GXL
PostPosted: Sun Feb 28, 2010 8:01 am
Are they wired backwards to other alternators? I had a sierra and the alternator died on it, so got it replaced with a bigger one off another car, (no idea what type or any details) and the alternator warning light stayed on instead of being off. Still put out 12V though.
Simplify and add lightness
PostPosted: Sun Feb 28, 2010 12:02 pm
Interested to see pics of this one fitted, to see how it compares to the Bosch unit...
1958 Morris Minor 1000 - "Nigel"
PostPosted: Sun Feb 28, 2010 10:17 pm
Forum Graffiti
Ask n ye shall receive :)
Pics might not quite show the size difference, but there's a fair bit in it...
PostPosted: Sun Feb 28, 2010 11:39 pm
The Suzuki Swift or Charade later type alternator with the internal fan is much neater, more efficient and compact.
and gives more room in a mini
See this thread http://www.ausmini.com/forums/viewtopic.php?t=33096
Users browsing this forum: Bing [Bot] and 97 guests
