It is currently Wed Aug 06, 2025 11:50 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 130, 131, 132, 133, 134, 135, 136 ... 568  Next
PostPosted: Thu Mar 04, 2010 9:30 pm
This space for rent
MiniKit wrote:
bargin basement price Contessas ... cheap for a reason
You may want to check them to make sure they're still approximately round...
PostPosted: Thu Mar 04, 2010 9:37 pm
Put the engine back in the Deluxe.
New engine mounts are a bugger when they are tight.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Mar 04, 2010 9:45 pm
Already done.. Oh and they are.... These are just going to be used in the interim until I splurge out on some shiny new more flasherer ones.
PostPosted: Thu Mar 04, 2010 9:49 pm
Did you use genuine Rover mounts or Quinton Hazell ones?
The QH ones are dimensionally wrong, the holes are 4mm out of position.
But I can fix this by slotting the holes, I've done 2 pair so far... see my recent thread here.
PostPosted: Fri Mar 05, 2010 4:16 am
The TIG
I bought some stainless steel for my Travelle"R". Also I build a bracket to mount some relays up under the dash, and also a mount for the ECU for under the dash.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Fri Mar 05, 2010 8:52 am
I used the genuine Rover ones.
Holes line up OK just hard to get them in position and keep them lined up while tring to insert the bolt.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Fri Mar 05, 2010 1:22 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
Fitted some HID headlights, nice blue 8) , I don,t know why though I hardly ever drive it at night :? . Must be a mini thing.
https://t.me/pump_upp
PostPosted: Fri Mar 05, 2010 2:24 pm
Did up an Oz rack for Betty. :lol:
PostPosted: Fri Mar 05, 2010 2:59 pm
Charged the battery, and went for a quick spin :twisted:
PostPosted: Fri Mar 05, 2010 3:10 pm
Pulled out the master cylinders for a reco, some bastard had used wire instead of split pins so getting them off the pedals was a pain.
PostPosted: Fri Mar 05, 2010 4:53 pm
Sanded the roof, door, bonnet and front left quatter panel last night and should have the car sanded back ready by monday. It would have been much easier if the PO had sprayed it or left it as it was but nooo, he had to hand paint the whole car black. :evil: :cry: :evil:
PostPosted: Fri Mar 05, 2010 6:15 pm
I took the 970 S motor out of my cooper car co replica and hope to have the 1275 in it buy tomorrow, of coarse I also had to change the 3 sync ST gear box as well which all takes time. The only set back that I can think of will be fitting the 45 DCOE weber with a 6" manifold :? I am not prepared to cut the bulk head and am at the mo unsure if it will fit.
PostPosted: Fri Mar 05, 2010 7:49 pm
I did nothing really but I do have a question
Austin costin why are you pulling out a 970 S motor and putting in a 1275 :shock:
PostPosted: Fri Mar 05, 2010 8:12 pm
Hmmm ... more HP is a good reason. :lol:
PostPosted: Fri Mar 05, 2010 8:27 pm
had front sub sandblasted at work. Sneaky foreign orders! 8)
mooo, I'm a pig!
