It is currently Wed Aug 06, 2025 10:42 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 131, 132, 133, 134, 135, 136, 137 ... 568  Next
PostPosted: Fri Mar 05, 2010 11:42 pm
Pulled the 1098 crank and pistons out of the spare block I had and checked it over.. It's had some work done. The oil journals line up with the holes in the bearing caps for one thing. It looks pretty good, might be time to have a stroker 998 :)
PostPosted: Sat Mar 06, 2010 7:03 pm
gafmo wrote:
I did nothing really but I do have a question
Austin costin why are you pulling out a 970 S motor and putting in a 1275 :shock:
You've obviously not driven a 970, all noise no go unless they are tuned within an inch of there lives :lol: besides the cooper car co mk2s all had 1275 non S motors.
PostPosted: Sun Mar 07, 2010 2:01 pm
Went for a pie run, to Pie in the Sky at Cowan.
Went up via Berowra Waters, and back via Galston Gorge.:mrgreen:
PostPosted: Sun Mar 07, 2010 5:35 pm
I honed my skills.....
Tossing the 1098 crank to the side of the shed until I get it re-ground or decide to use it as a door stop. The pistons skirts are all scored aswell, so something nasty must have happened to it at some stage.
When people put new rings on do you use the pliers that are available or do it by hand and pray to the mini gods that they don't snap? I've done it by hand beore on a Hilux ute, but I considered myself extremely lucky that time around..
PostPosted: Sun Mar 07, 2010 6:00 pm
i just use my hands, you just need to support opposite from the gap
PostPosted: Sun Mar 07, 2010 6:57 pm
How was the pie?
PostPosted: Sun Mar 07, 2010 7:22 pm
Finished putting the engine in the deluxe.
Bled the clutch,
Bled the brakes
Took the car for a test drive.
All finished but probably needs a good tune now.
Before - broken gearbox and crappy paint job.
After - reco gearbox, reground camshaft, new bearings nicely painted. :) :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Mar 07, 2010 7:53 pm
Completed build sheet for '71 Clubbie project. Made inventory of parts on hand. Why would I need 9 gearboxes :?: No wonder I can't move in garage :!:
PostPosted: Sun Mar 07, 2010 8:00 pm
How was the pie?
Steak and cracked pepper. mmmmmmmmmm. Excellent, as usual. :P
PostPosted: Sun Mar 07, 2010 9:39 pm
Bled the clutch,
Bled the brakes
Looks really good :D :D
PostPosted: Mon Mar 08, 2010 4:34 pm
On the weekend I:
Pulled out the old dash, dash cards and the carpet that was on the shelf plus the dodgy speedo housing I had put in and replaced with new:
- Vinyl dash mat
- Vinyl dash cards
- New oval dash with my nice new gauges, except speedo (its on the list)
- New chrome tacho pod - plus fixed/tidied the wiring
I also fitted headlight grilles
Removed the stereo from its mount and fixed it plus some wiring. Also fixed the amp.
Fixed up the wiring for my parking lights.
Next weekends list includes. sanding and painting new steering column and shroud + fitting both.
Modifying my seat mounts so that they are more upright.
Maybe making an under-seat speaker board.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Mar 08, 2010 5:57 pm
Ryan didn't you have a round binnacle before?
Did nothing on my mini but replaced the clutch line on Molly for Andy although not sure how successful it was
PostPosted: Mon Mar 08, 2010 6:50 pm
Managed to limp my mini to work with its blown headgasket today, so when i knocked off i pulled the motor out in the hour i waited for my dad to pick me up. Guess i'm going to be building my new supercharged motor quick now as the mini is my daily drive.
PostPosted: Mon Mar 08, 2010 7:40 pm
Yeah I did have an oval binnacle before, but it was the type with green lights in it, but never actually had the lights. But because i'm putting everything MK1 on it, i changed to this style and I have the mk1 indicator arm to go on (the type with the green light on the end.
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Mar 08, 2010 7:41 pm
Set Gafmo's GR modified 202 head up on the mill so I can deck it in the morning. :wink:
