It is currently Thu Aug 21, 2025 9:35 pm
PostPosted: Mon Mar 08, 2010 9:58 pm
Does anyone know if there is supposed to be a rubber washer/seal that goes between the steering rack and the shell? I can't remember there being one but it looks like something's supposed to be there...
PostPosted: Mon Mar 08, 2010 10:59 pm
it was a felt originally
PostPosted: Mon Mar 08, 2010 11:06 pm
Damn hard to find in parts books. Basically, its flat spongey round seal about 1 1/2" in diameter which stops the dirt & water entering. If you can get hold of some soft spongey rubber about 5 mm thick so it compresses when you bolt up the rack, that should do the trick.
PostPosted: Mon Mar 08, 2010 11:09 pm
cut up an old thong
No,,, not "That" type of thong you dirty old men :-)
PostPosted: Tue Mar 09, 2010 5:49 am
Mods rock!
P/N 21A30, should cost you all of about $1.50. They are 12mm thick when new and a soft foam rubber, but when they're squashed they don't come back. If you make one from a thong, don't cut the centre hole too small, you don't want that tight at all.
Oh and panties are way better than thongs..................
PostPosted: Tue Mar 09, 2010 8:08 pm
Last time I replaced one I used an old mouse pad and cut one to fit.
Cheers Pete
PostPosted: Tue Mar 09, 2010 8:24 pm
doogie once mentioned that he uses the bottom off a stubby cooler!
Every blokes got a collection of them laying around! :lol:
mooo, I'm a pig!
Users browsing this forum: No registered users and 196 guests
