It is currently Wed Aug 06, 2025 9:12 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 134, 135, 136, 137, 138, 139, 140 ... 568  Next
PostPosted: Sun Mar 14, 2010 7:44 pm
Angusdog wrote:
Yesterday I installed the adjustable lower arms, tie rods and rear camber brackets
Are those the Huddersfield type?
PostPosted: Sun Mar 14, 2010 10:56 pm
Assembled Triger timing belt assembly. Found I'm missing the spacer/guard for the crank pulley from the kit.... Grrrrrr
Put Clutch casing back on with new main seal and gasket.
Such fun..
PostPosted: Sun Mar 14, 2010 11:02 pm
Milatsmadmini
Sure is...
PostPosted: Mon Mar 15, 2010 5:20 am
Yep, they are, although I got them from Minisport. I prefer not having to wait for a shipping quote; Minisport gives it to you instantly so you can price up various options. If I need a heart atatck, I price up some of the panels I need...
PostPosted: Mon Mar 15, 2010 4:18 pm
Picked up the mini deluxe from Mini Classic.
Wow what a difference. :shock:
It now revs and pulls hard up hills in 4th gear it would previously need 3rd gear for. :D
The distributor was not providing any advance and the carby needle needed a tweek.
Very happy! :D :D :D
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Mar 15, 2010 4:39 pm
The TIG
Built a stainless steel exhaust system.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Mon Mar 15, 2010 6:02 pm
Milatsmadmini
Was that in a Kit Kiwi or did you buy both parts individually? (im lookin at getting the same thing with the adjustable bottom arms...?)
PostPosted: Mon Mar 15, 2010 8:38 pm
decided on what the colour of the Fan will be :roll:
PostPosted: Mon Mar 15, 2010 8:44 pm
Milatsmadmini
AND????
PostPosted: Mon Mar 15, 2010 8:51 pm
TOK-TIK-TOK-TIK-TOK-TIK-TOK-TIK
I now have an indicator that's consistent and doesn't pause on 'on'!
PostPosted: Mon Mar 15, 2010 9:33 pm
Online
Had a big day on the race car, first up had the exhaust repaired at the local friendly exhaust shop, then home for oil & filter change, checked/re-set the tappets, cleaned out the breather overflow catch can, replaced brake and clutch fluids, full grease, re-aligned the doors and adjusted door latches.
Lastly, had mobile sparky fit a new terminal to battery cable for starter motor, which is one of Tony's (Convertible Mini) modified Bosch starter motors which is just the ducks' nuts :wink:
Steve
PostPosted: Wed Mar 17, 2010 7:17 pm
Drew up a new wiring loom to suit the new fuse panel I put together.
This panel will be mounted under the dash on the passenger side and will be on hinges to swing down. There are individual fuse circuits for those feeds requiring permanent battery, circuits rquired on the AUX ignition position and for those on the ON position.
Tomorrow I will wire up the loom on the template I have drawn up on a suitable piece of ply following the colur convention of purple for permanent battery, green for auxillary, white for ignition on feeds and brown for direct battery supply.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Wed Mar 17, 2010 9:05 pm
I was going to do this also for the Van also. I am putting my fuse box & relays in the same position but the idea of the wire length when it swings down...I thought..hmmm bugger it just bolt them up into position. Really intersted to see how you do it 8)
PostPosted: Sun Mar 21, 2010 10:49 am
Hooked into mine yesterday, we got the wheels on, and were all ready to finally having a crack at putting the friggen door/windows back together. Been putting it off for weeks and thought just better do it :roll: !
After i worked out the order in which i pulled em apart (it has been awhile :lol: !), worked out what order bits go back on......................then discover am missing clips to lock chrome and felts and bits on :evil: ! NOT HAPPY!
Best be ringing minisport in the morning!
PS: 'BITS' is obviously my 'chick technical term' for the things i don't know the names of :oops: :lol: !
Cheers, Kim :-)
**purple '68 deluxe!**
***FINALLY wearing number plates----yeaaaaaah baby! ***
PostPosted: Sun Mar 21, 2010 11:57 am
Sort of Mini again - fixing the workshop so I can work on the Mini - bought 10 double fluro light boxes for $8 each off eBay (Bunnies are $40 each for a double slimline) - the guy still has 12 left if any Brisbanites need some. Have been told that will make it bright enough to see the dust settle on a new paint job :roll:
David L
