It is currently Thu Aug 14, 2025 6:07 pm
 Post subject: Speedo issue
PostPosted: Sun Mar 21, 2010 2:13 pm
Hello all
I have a clubman speedo that isn't working. I have put on a new cable and the inner bit seems to have a positive connection to the gearbox.
The needle slowly crept up to 60kph and then it just stopped there. This leads me to believe the gauge is a bit buggered.
Is there anything inside them that I could fix?
Thanksyou
blokeinamoke wrote:
PostPosted: Sun Mar 21, 2010 2:26 pm
Mods rock!
Sometimes the inner cables are a wee bit too long. To test for this you could loosen the outer on the back of the speedo (if it's a screw on type). If that makes it work, I would suggest grinding a small bit off the length so you can tighen it up again.
Failing that, the speedo heads are servicable, however you might be best to take it to a specialist or simply get another.
PostPosted: Sun Mar 21, 2010 2:36 pm
Thanks wogs, I will go and try it. I am chasin a new one at the moment regardless..
blokeinamoke wrote:
PostPosted: Sun Mar 21, 2010 9:05 pm
the odometer keeps working but the needle is stuck. I have wriggled it and it doesn't seem jammed or anything.
Anyone know the finer details of the insides of a speedo?
or should I just work out how long it will take me to cover 100m at 50kph 60 kph etc etc
and then just time every 100m and work it out that way?
cheers again
blokeinamoke wrote:
PostPosted: Sun Mar 21, 2010 9:32 pm
there will be a little plasic gear inside the speedo that is stripped or missing teeth or something like that
easy fixed by a Guage/instrument specialist
PostPosted: Mon Mar 22, 2010 9:31 am
okie dokie, I will pull it to bits and if need be I will cut another gear for it.
blokeinamoke wrote:
PostPosted: Mon Mar 22, 2010 11:16 am
If the odometer (distance counter) is working it's not the plastic gear.
The speedo needle shaft is jammed in the bearings probably.
They cost around $200 to fix... (Mk2 S speedo with jammed needle).
What speedo is it, might be easier to find another. :wink:
PostPosted: Mon Mar 22, 2010 11:50 am
As a kid back in the 60s, there were lots of Austin Oxfords whose odometers did not work. These cars were used as Taxis back then (not in Australia).
I kinda remember the dial as the same one used in the Mini.
Any suggestion who'd be able to fix them? I have a same problem with my Mini. There was a guy who does this in Croydon (sidiney), but he retired several years ago.
1966 Morris Mini Deluxe
.... 4 bicycles and 3 screaming kids.
PostPosted: Mon Mar 22, 2010 11:59 am
My mate sent his Mk2S speedo down to Howard Instruments in Melbourne. It cost him around $200 to fix.
I used to use Olympic Instruments in Pymble years ago, I'm not sure where they are now but they are still going.
There is also a bloke in Marayong (near Marayong wrecking yard, off Vardys Rd) who does up Mini speedos, I've not used him though.
PostPosted: Mon Mar 22, 2010 12:22 pm
the last one on ebay went for 80 bucks,
blokeinamoke wrote:
PostPosted: Mon Mar 22, 2010 1:32 pm
Mods rock!
Regretably Olympic Instruments are no more. I used to use them a bit and they were not only quite good at what they did, but fairly priced. The also had the Police Contract for Speedo Calibration in and out of car.
Howards have a very good name and they know it, so you pay for their 'goodness'.
Last time I needed a repair (Capillary temp gauge), I took it to these guys;-
http://www.yellowpages.com.au/nsw/lidco ... sting.html
They did an OK job and priced OK.
In Adelaide, you could try;-
http://www.yellowpages.com.au/sa/mypong ... sting.html
Sorry, I don't know anything about them, but it's only a phone call.
Users browsing this forum: No registered users and 280 guests
