It is currently Fri Jul 25, 2025 12:16 pm
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Mar 31, 2010 3:54 pm
It's supposed to be a 1966 - in that case should it have a 970cc? Twin tanks came standard in 1966 so they might be ok.
Regards,
Mike
"He who dies with the most toys wins."
PostPosted: Wed Mar 31, 2010 4:59 pm
It has Aquajets. :evil: I hate Aquajets.
PostPosted: Wed Mar 31, 2010 5:07 pm
66s is spot on, it should also have upper and lower dash vinyle fitted, also if it were a 66 it should be hydro and certanly not 970.
Personaly I would say that the only way to authenticate without a doubt IS to get a heritage cert, this will give you CC rating, colours, date built, date dispatched, extras, and where it was registered and also if it were for export, an english cooper S is'nt worth a toss without one, and there is no reason for not being able to aquire one for a mk1.
Heritage certs have been known to be wrong but generally give you enougth facts to base buying an authentic car.
Although, to me it shouts either badly restored OR clone!
PostPosted: Wed Mar 31, 2010 5:16 pm
Enouigh said I believe - it has some doubts...so..NO DEAL
Another successful foray into the members knowledge base. :D
Regards,
Mike
PostPosted: Wed Mar 31, 2010 6:16 pm
As Matt says that looks like a 1275 block to me, look at the height at the corner, below the heater tap.
970 and 1071 blocks are 3/8" shorter.
So how does the engine number point to a 970?! :shock:
Regards,
Mike
PostPosted: Wed Mar 31, 2010 6:20 pm
Mike_Byron wrote:
The over spray on the door strikers certainly makes you wonder if its had a touch up spray or accident repair at some stage. Thats not a problem if its been properly done.
Mike
The door strikers should be painted body colour, this is often thought to be incorrect but that is how they were built....average I know!
PostPosted: Wed Mar 31, 2010 6:24 pm
They did live up to their name though, as soon as you hit water, your car would take off like a jet and try and kill you! :mrgreen:
PostPosted: Wed Mar 31, 2010 6:25 pm
You said 9F-SA - 7 42346. This can't be right so some people have turned the "7" into an "X" to make it a 970 motor.
I would probably assume the "7" is a "Y" which would make it a 1275.
It works like...
970 = X
1070 = H
1275 = Y
PostPosted: Wed Mar 31, 2010 6:28 pm
I don't think it does.
`9F SA' was prefix to 997 Cooper, 970S, 1071S, and Mk1 1275S.
There is a letter missing... if X it is a 970, H is a 997 or 1071, Y is a 1275...
Taken from p50 of my John Parnell Cooper & S book.
PostPosted: Wed Mar 31, 2010 7:19 pm
It works like...
970 = X
1070 = H
1275 = Y
I was wondering how long it would take for the x to be a y :wink: , as it probably should be
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Wed Mar 31, 2010 7:52 pm
It would be easy to mistake the Y for a 7? Which would mean it is a 1275?
Regards,
Mike
PostPosted: Wed Mar 31, 2010 8:16 pm
Yes it would.
PostPosted: Wed Mar 31, 2010 10:58 pm
My dad had a 970S and I remember it had the wire type door check straps not the seatbelt webbing ones
I believe Ivan at Castle Hill has a 970 maybe he can help
PostPosted: Thu Apr 01, 2010 5:14 am
simon k wrote:
66S wrote:
My Sept. '66 Morris Cooper S is 190 engine numbers later and the body number is A056546.
yours is a 970?
No, it's 1275.
Regards
Al
Users browsing this forum: Bill B and 88 guests
