It is currently Fri Aug 08, 2025 5:46 am
 Post subject: Imp Piston and Rings
PostPosted: Sat Apr 03, 2010 5:16 pm
Anyone know of a good supplier for STD flat top hillman imp pistons and rings?
just preparing for the worst, i may need to renew them depending on the engineering shops findings this week.
could find any listings on australian mini parts websites.
thanks in advance 8)
PostPosted: Sat Apr 03, 2010 5:47 pm
they are hens teeth these days (i've heard), and if your desperate you can get some custom made up (i think there is a company in wa that does it)
Others will know better.
just get another small bore block (998 or 1098 doesnt matter they are the same) this may be a cheaper option than having some custom made
PostPosted: Sat Apr 03, 2010 5:49 pm
yeh this is why i want to price how much they are. if they are rare and expensive then it is not worth going down that road.
8)
http://www.jp.com.au/JPPistons.html
PostPosted: Sat Apr 03, 2010 6:55 pm
JP pistons makes them, I would buy their rings but not the pistons.
If I wanted Imp pistons to go in a Mini I would import them.
PM me for reasons why.
PostPosted: Sat Apr 03, 2010 9:30 pm
You could try http://www.impwerks.co.nz/ in NZ, for something like a set of pistons postage isn't going to be a big deal.
I'm assuming that you want standard 875 pistons for a 1220 conversion, not the bigger bore 998 pistons. AFAIK there are no Imp specialists in Australia. .
66 Deluxe, 07 Cooper
PostPosted: Sat Apr 03, 2010 9:50 pm
I enquired at Impwerx NZ a few years ago and got quoted ~$800/set from UK for 875cc Imp (68mm) pistons. If available.
These were a good idea here 30 or 40 years ago, when we could buy them everywhere, but at the sort of prices now and lack of availability I'd go with Graham Russell's +.100" flat tops at under $300/set. To use these you don't have to mill .150" or so off the block like you need to with the Imp ones.
[edit] they give you 1188cc.
Last edited by drmini in aust on Sat Apr 03, 2010 9:56 pm, edited 2 times in total.
PostPosted: Sat Apr 03, 2010 9:52 pm
cool, thanks for your input guys. i will make a few calls this week and see what i can find.
in the mean time i will wait for the machinst to have a good look at it and go from there.
8)
Users browsing this forum: Bing [Bot] and 95 guests
