It is currently Mon Jul 21, 2025 5:35 pm
 Post subject: Engine stand
PostPosted: Wed Mar 23, 2005 1:48 pm
Can anyone recommend an engine stand which will bolt a mini engine on it nicely?
PostPosted: Wed Mar 23, 2005 3:31 pm
Yes, workbenches do wonders, but it might be hard to find a clean one, so it's just easier to get another, but then you have to clear out a place on the floor, which it too hard to get around, so just extend the garage, but the......
Supercrap might have something though, or if you can use a welder, make your own, then put big wheels and a sound system in it..
EDIT: Sorry about this whole useless message. I'll try better next time.
PostPosted: Wed Mar 23, 2005 3:34 pm
from what i gather.. people generally modify a standard engine stand to hang the engine/box assemby off..
Expert in training
PostPosted: Wed Mar 23, 2005 7:17 pm
I modified my toolmac stand using a mini alternator bracket and welding on a length of pipe. Good for engine blocks and maybe cranks but doubtful about a full engine and gearbox.
PostPosted: Wed Mar 23, 2005 7:44 pm
Kev,
If you bolt a plate on the oil filter boss, then weld a pipe up to it, it'll hold a gear box too, no problem!
PostPosted: Wed Mar 23, 2005 8:31 pm
Kev,
yeah, I hadn't forgotten you mentioned that when you were 'round. I my try that before it gets to the re-assembly stage. Would take two people to spin it around after fitting the gearbox on I would imagine.
PostPosted: Wed Mar 23, 2005 9:57 pm
1310/71 wrote:
Kev,
Depends... where you put the centre of balance.. :wink:
PostPosted: Thu Mar 24, 2005 9:47 am
I don't have any welding gear.
What's going to be my best solution for having an easily accessable and movable engine/gearbox in my garage?
PostPosted: Thu Mar 24, 2005 12:16 pm
On another forum, someone mentioned this option (although I am not condoning it).
Steal a supermarket trolley, cut the basket off it and just use the base and handle (may have to put some plywood on the base to support the gearbox).
Although it's not an engine stand, it does make storage and moving it around a cinch.
KB
PostPosted: Thu Mar 24, 2005 12:34 pm
steal a trolley? i wouldnt go around recommending that
Expert in training
PostPosted: Thu Mar 24, 2005 2:15 pm
Nah, no good. You would end up with an engine stand that wobbled, wants to keep going around in a circle or you have to push really hard.
Over 1,000,000Km, but now my retirement restoration project
PostPosted: Thu Mar 24, 2005 2:21 pm
Engines arent that heavy.
They don't buckle 3mm steel :roll:
One of those pov pack sack truck things will do the job for getting it around. Just over inflate the tires, but not too much.
Too easy :wink:
