It is currently Mon Jul 21, 2025 5:58 pm
 Post subject: Bloody engines....
PostPosted: Wed Mar 23, 2005 4:51 pm
NOT Turbo related, could have happened to anyone....
I noticed at the dyno day that my lower pulley was a little loose, so when i took it home, gave it a good tighten....
Well it came off last weekend ! (about 1 k from home, so no over heating or charging issues...)
Put another one on there last weekend, it just let go 10 mins ago !
Guess the keyway is ferked on my crank .... bugger..... engine out jobbie !
Oh well, any suggestions while it is out ?
J
PS - couldnt have come at a worse time, Easter, raining, Commodore in the shop getting unbent, bugger.
PostPosted: Wed Mar 23, 2005 4:53 pm
a good clean polish alloy bits and a coat of paint cause clean engine bays are great :)
PostPosted: Wed Mar 23, 2005 4:56 pm
Agree 8)
Didn't they right the Dunnydoor off :shock: :cry:
PostPosted: Wed Mar 23, 2005 4:58 pm
Nope.... :evil:
They are going to have it back by the end of the month though.... all nice and straight and shiny.... apparantly....
If its not 100% its going back until it is .... ferking Germans....
J
PostPosted: Wed Mar 23, 2005 5:00 pm
Rear Bumer then :?
PostPosted: Wed Mar 23, 2005 7:24 pm
I'm in the middle of an engine rebuild myself 'cause my harmonic balancer was loose and rattly - so I decided to rebuild the engine as you do. When I looked at the keyway the other night it was cracked and broke in two when I tried to get it out. Hard to say if it broke first, or the movement of the pulley stressed it. Probably the latter.
I like freshly painted engines. Whilst it's out, time to freshen it up I say.
Kevin.
PostPosted: Wed Mar 23, 2005 7:29 pm
I bet the keyway in the crank is OK, just the key & pulley is ****..
Get thee a new crank key.. :wink:
PostPosted: Wed Mar 23, 2005 7:44 pm
I've got a few newies....
Just want to avoid splitting the engine and 'box again....
Cant get anything but a straight pulley in there without pulling the engine !!
Its crazy i tells ya....
got any secrets ?
J
PostPosted: Wed Mar 23, 2005 7:46 pm
James,
You can get it all off in situ, I've done it lots of times. Need to pull the timing gear too, then chisel that crank key out..
I'd put a 1098 balancer on it if you have any left.. :lol:
PostPosted: Wed Mar 23, 2005 8:34 pm
Sorry, me confusing part names. The keyway is Ok, it was the crank key which broke in two. :oops:
I've got a Mk1 S balancer (excellent condition) was going to use that, but there isnt enough room between the snout of the crank and the metal "mount thingy" on the end of the gearbox.....
Just cant manouvre a balancer in there.....I'll need to order a timing cover seal and gasket in the morning then.... should get it friday....(post on Good Friday ?)
Get it done Saturday, ready to take family out to roll eggs on Sunday !
J
PostPosted: Wed Mar 23, 2005 8:36 pm
Whats the differnce between an 1275 balancer and an 1100 S one ?
Any ?
Part numbers?
J
PostPosted: Wed Mar 23, 2005 9:13 pm
Just grind the metal mount thingy for clearance. Remember to allow enough clearance to fit a fan belt over the balancer when in the car. The 1100 one is smaller, be easier to fit.
Steve
PostPosted: Wed Mar 23, 2005 9:47 pm
Any ?
Part numbers?
J
1100 balancer and 1275 balancer (1100S & later) are the same thing.
One piece type.
PostPosted: Wed Mar 23, 2005 9:50 pm
Cool ...
and the preferred one is.....
"S" or 1275 ?
Guessing the "S" one....
J
Users browsing this forum: Bing [Bot] and 66 guests
