It is currently Wed Jul 30, 2025 1:24 pm
PostPosted: Mon Apr 05, 2010 5:07 pm
ok so drove moke fine the other day. Drove it this morning and it was fine.
Moved it from the garage to the end of the driveway and smelt petrol. Drove it back down to the garage (after nothing worked on the Rover who is now waiting to be taken to hospital - or the wreckers) and the smell of petrol was very overpowering
opened the bonnet and there was petrol dripping (lots) on the extractors
Dried everything down, left it for 5 mins to cool and came back. Removed the air filter and turned the key to power the fuel pump.
Petrol was pouring out of a hole under the inlet in the top of the float bulb. Strangely (after a few beers) i cant understand why all of a sudden petrol is pouring out of this hole. The hole has always been there. Petrol has always been there. Petrol coming out of the hole hasnt happened before,.....
OMG i am writing so much.
Cut long story short, the float chamber is filling with fuel and coming out of the hole under where the petrol goes in and its going everywhere...........
HELP...
:cry:
one mini.......... JUST ONE MINI IS ALL I WANT ON THE ROAD..!!! ONNNNNE!!!!
PostPosted: Mon Apr 05, 2010 5:10 pm
Needle valve/seat in the float cover is sticking or full of crap.
Take it off and clean any crud out first.
If no fix, replace the needle valve & seat. Check float level.
Or, the float has a pinhole and sunk, but this is rare.
PostPosted: Mon Apr 05, 2010 5:12 pm
The needle and seat is not closing for some reason. It could be a speck of grit or the float has turned into a sink or just the needle stuck.
The easiest trick to try and cure the most likely problem is to whack the top of the float bowl with the handle of a screwdriver. A screwdriver has about the right weight to do the trick without damage.
PostPosted: Mon Apr 05, 2010 6:57 pm
Do you run a filter before the carby,? The Doc & Morris 1100 have your problem covered i'd say.
PostPosted: Tue Apr 06, 2010 1:50 pm
OK so number 24 is the needle and seat assembly (as per below schematic) but where is this located? Sorry am trying to knowledge myself up on it before i go home and pull it apart...
I am presuming that it is in the lid assembly that when the float bulb rises as fuel enters the chamber it then lifts the needle whcih closes off the flow of petrol into th chamber until you suck it into the carbie to use it which causes the bulb to go down and more fuel to enter????
God i feel like a newbie.... :shock: :lol:
PostPosted: Tue Apr 06, 2010 2:10 pm
You are correct, you have won the kewpie doll. :D
All in the lid.
Take the pin out that the float swings on, and the needle, then undo the jet with a 1/4 drive socket.
The early floats with the metal strip on top let you adjust the float level by bending it.
Later 1 piece nylon floats have no adjustment they are a PITA. Only adjustment is a shim washer under the jet.
PostPosted: Fri Apr 09, 2010 12:55 pm
YAY..!!! She is all fixed..... ANNNND I learned something.... ANNNNNNNNNNNNNNND i even fixed the battery and took out the V bottle that was previously keeping it in place.
Starts first go every go at the moment with no smell of petrol.
Thanks guys
PostPosted: Fri Apr 09, 2010 1:01 pm
Well done for gettting your hands dirty, solving the faults and not just taking it to a mechanic!
PostPosted: Fri Apr 09, 2010 1:19 pm
Thanks guys
You are learning, grasshopper...
Now, how is that )%#$*(&^ Rover?? :evil:
PostPosted: Fri Apr 09, 2010 4:04 pm
Thanks guys
well (not wanting to offend Hanra) she is being booked in to visit Uncle Greig early next week.... fingers crossed.........
PostPosted: Fri Apr 09, 2010 4:23 pm
Thanks guys
Ask Greig nice, & he might do a house call..? You're pretty close.
Users browsing this forum: Barkfast, winabbey and 87 guests
