It is currently Mon Aug 18, 2025 5:52 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Apr 09, 2010 8:48 am
Sean
I wrote on and posted some photos on your facebook wall - maybe helpful ????
Mike
PostPosted: Fri Apr 09, 2010 3:12 pm
thanks mike, it did help slightly.. i still think the needle is wrong..
alot of people seem to be running a bdl needle for my setup and have no issues
so.. who has one of those?
i need one asap :lol:
Potato
PostPosted: Sat Apr 10, 2010 1:35 pm
i might put a different coil on the thing too... what is the part number for an electronic igniton friendly coil that i can get from supercheap or something.. im pretty sure they stock bosch ones.. and from memory i had a vl commodore one on the race car..
could the coil be doing what im saying.. it sounds like a lawn mower at low revs in 3rd and 4th gear...
Potato
PostPosted: Sat Apr 10, 2010 5:32 pm
i have a gt40t coil laying around will that work.. im assuming not.. :roll:
Potato
PostPosted: Sun Apr 11, 2010 8:27 am
Those are 3 ohm. It won't hurt it to try it. Even if your dizzy (what model?) has a 1.5 ohm one now.
PostPosted: Sun Apr 18, 2010 3:17 pm
new coil, no different, new rotor buttong.. no different.. ive now changed everything that could be at fault... what now :roll:
could i have a poorly setup dissy or incorrectly mapped one for my engine.. i havnt got any others to try and the closest mini place is an hours drive from me so buying stuff and trying it is becoming 4 figure style expensive
Potato
PostPosted: Sun Apr 18, 2010 4:41 pm
there u go.. listen to it..
Potato
PostPosted: Sun Apr 18, 2010 7:39 pm
dead lead / leads
to prove my point, take 1 lead off at a time and see if it changes the way it runs.
When you find the lead that makes no difference you have the culprit.
I got a set of leads from an auto store for about 40$.... they come in all sorts of lengths so knocking up a set that fits nice is easy.
at that price. why not?
I have just spent weeks trying to sort a similar problem....... its always the simple things.
blokeinamoke wrote:
PostPosted: Sun Apr 18, 2010 7:45 pm
ive tried two different sets of leads but if thats what you reckon.. can i pull the leads off a car with electronic igniton and not die?
Potato
PostPosted: Sun Apr 18, 2010 7:49 pm
If you pull the lead off at the plug you are holding a live lead.
If you pull it off at the dizzy end you are holding an inert lead. :wink:
PostPosted: Sun Apr 18, 2010 7:50 pm
lol i dont understand :lol:
Potato
PostPosted: Sun Apr 18, 2010 7:53 pm
pull out the lead from the distributor end so you won't get electrocuted
PostPosted: Sun Apr 18, 2010 7:54 pm
You will if it bites you! :lol:
PostPosted: Sun Apr 18, 2010 8:00 pm
yep that didnt work... all of them are sparking.. and when the coil one came off accidently in the process i nearly hit the ceiling... fun times
Potato
PostPosted: Sun Apr 18, 2010 9:03 pm
if your getting spark at all leads how are the plugs..All the same
are they dry and black
Users browsing this forum: No registered users and 332 guests
