It is currently Fri Aug 01, 2025 1:36 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Steering rack
PostPosted: Mon Apr 12, 2010 6:41 pm
Good question by Mearcat...I'm at the same stage.
Looking inwards, regarding the drive box, what do you pack that with and can you replace the seal round the spline where the steering column goes? Where do you get them?
Would you also grease under the boots? The oil will tend to sit at the bottom of the boot and only get shaken round once things start moving?
Regards,
Mike
"He who dies with the most toys wins."
 Post subject: Re: Steering rack
PostPosted: Mon Apr 12, 2010 7:15 pm
The seal is available from Karcraft, Mini King and others.
After assembling the rack I put it in middle position, fit the LH boot & clamps, and stand it on its end in the vice, gearbox end up.
Then I pour 200mL of gear oil in. It takes 10 mins or so, as air comes up from below.
Then I fit the RH boot and clamps.
As I said before the problem with the grease they used to use (EP2 or similar) is it's too thick, and it goes hard. Then there is NO lube, as the rack has cut a path through the old grease.
The driest thing in the box is always the top bearing.
1/2 these racks I'm doing up had grease in, only 1 of those had grease that was still thin enough to lube itself. The rest were all dried out.
As Diecast (and I) said, it's best to use gear oil, not grease.
Cam Gears never recommended grease be used in these racks.
With 200mL of oil in there, it gets sloshed from end to end as you steer, lubricating everything- including the inner tierod joints.
Last edited by drmini in aust on Mon Apr 12, 2010 7:18 pm, edited 1 time in total.
PostPosted: Mon Apr 12, 2010 7:17 pm
And the spline gearbox?
Regards,
Mike
PostPosted: Mon Apr 12, 2010 7:19 pm
that's part of the rack, the oil sloshes through it.
PostPosted: Mon Apr 12, 2010 7:23 pm
Ah ha...I hadn't actually pulled the ends of mine yet and was working under the assumption that the centre was sealed (like a diff) and the end joints had their own lube...how wrong!
Regards,
Mike
PostPosted: Mon Apr 12, 2010 7:57 pm
Grease replaced oil in Cam Gears/TRW racks in the mid 80's. It was not an over the counter grease but was batched using EPL1 as a base with moly added.
To improve lubrication of the contact point between the back of the rack and the yoke a smear of "STP" oil additive was dabbed on the back of the rack during assembly. Grease was used on the Rack and Pinion teeth.
Oil or Grease? well if your rack needs a rebuild after 20,30, or 40 years of being lubricated with oil, who can complain, the oil is doing a fine job.
PostPosted: Tue Apr 13, 2010 6:02 am
diecast wrote:
Yep, as usual the doc is right, use oil. what ever is thickest you can buy. The original oil was about the consistency of honey straight from the fridge.
Semi Fluid Grease is pretty much that. It runs but slowly.
Al
