It is currently Sat Aug 16, 2025 7:05 am
PostPosted: Tue Apr 13, 2010 10:55 pm
Anyone here give me any reasons why I can't or shouldn't do this? It would be of great convenience to my car build if I can hide it in or under the boot.
It wouldn't change how everything is connected up as far as their order goes, just the lengths of the pipes / tubes from where they once were.
Since I don't fully understand how often this valve is used or kicks in, could I be looking at having vacuum problems or delays / lags of you will that may cause problems?
Thanks.
:D
EDIT:
This I got from a rover manual:
Evaporative emission canister
The evaporative emission (EVAP) canister is
situated beneath the LH inner wing valance, and
contains charcoal which absorbs and stores fuel
from the fuel tank when the engine is not running.
When the engine is running the vapour is purged
from the canister into the engine and burned.
The EVAP canister is purged when the EVAP
canister purge valve is opened. Manifold depression
draws fresh air into the canister through the
charcoal, which releases fuel vapour into the inlet
manifold.
Evaporative emission canister purge valve
The EVAP canister purge valve is operated by the
ECM. The valve remains closed until engine
temperature rises above 70°C. This is to maintain
engine tune and catalyst performance. If the valve
was to open with the engine cold or at idling speed,
the enriched mixture would delay catalyst light off
time and cause erratic idling. When the purge valve
opens, fuel vapour from the EVAP canister is drawn
along a pipe through the valve and into the inlet
manifold for combustion.
Blind shot in the dark here but moving it won't do squat, right?
PostPosted: Tue Apr 13, 2010 11:23 pm
Most people relocate them to the bin...
They don't do a damn thing performance wise, almost have rarity value now!
Noli Illegitimi Carborundum
PostPosted: Tue Apr 13, 2010 11:40 pm
I fitted mine under the wheel arch as per the front cut it came from.
Next time it'll just go straight to the bin.
It shouldn't matter how long the pipes are though if you want to put it somewhere else on the vehicle.
Image Image
PostPosted: Wed Apr 14, 2010 8:34 am
I've heard that they are useless after a couple of years. The charcoal stops doing its job apparently.
I've also heard that your car wont pass emission tests without it. But being Australia and not California, that shouldn't matter either.
PostPosted: Wed Apr 14, 2010 9:17 am
I would be worried about petrol fumes in the boot. They could build up if you have a petrol overflow from the carby.
Then one day you need to jump start the car or hook up a battery charger. One spark and bang.
Even just a little petrol vapour makes a pretty big bang and the force of it can only come out the back of the car where you are.
Mike
PostPosted: Wed Apr 14, 2010 9:37 am
You have a point there Mike, but the unit does have a breather tube I'd be hanging through the floor if I don't hide the whole thing down there, so I don't think there should be any more fumes in the boot than there normally would be (provided the hoses all correctly seal).
I didn't want to put the thing in the wheel arch as its a PITA to get under there and fit the bracket, plus it would make the piping neater under the bonnet.
Something to think about.
Thanks guys.
:D
PostPosted: Wed Apr 14, 2010 9:39 am
unless the valve stays in the engine bay, I'd expect that a vacuum pipe running all the way back to the boot would have an adverse effect on performance
PostPosted: Wed Apr 14, 2010 11:15 am
The valve isn't going anywhere, I can't be bothered rewiring the engine harness to extend it.
:D
Users browsing this forum: No registered users and 355 guests
