It is currently Wed Aug 20, 2025 6:33 pm
 Post subject: going to look at an 850
PostPosted: Tue Apr 13, 2010 7:58 pm
gday im going on saterday to have a look at an 850 for resteration i have not seen the car
could some of you post detaels on where to look for rust so that i can makle myself a list so that i dont forget to look any where that maybe i should have
also is there any areas that could be to badly rusted to bother with restoration ,, what are they
thanx in advance for your replies
james..
PostPosted: Tue Apr 13, 2010 8:25 pm
Umm obvious places
- a-panels
- floor pans
- boot floor
- back seat where the the boot joins the bottom of the seat
- Beaver panel
- Sills
These not overly hard to fix (hardest being seat in my opinion)
I looked at an 850 about a year ago and the Front valance panel (below front bumper) had rust in it (these panels witout the cutouts for cooling the brakes as far as im aware are not available anymore)
take a scew-driver with you and give bits and pieces a good poske to know whether the rust is surface or not
But really i dont think there is any rust spot thats not repairable (see micks cooper s he fixed)
Just be WARY!!! of bog or plates - Its surprising what bog can hide or what can be under plates
Dont know if that helps but yeah
PostPosted: Tue Apr 13, 2010 9:00 pm
Try looking around the vertical seams, these are usually rusty.
And if its got decent paint on it look far parts that look different to the rest of the car. There could be filler underneath.
If they wont let you poke suspicious looking bits then walk away.
Simplify and add lightness
PostPosted: Tue Apr 13, 2010 9:19 pm
The Mini King
A small magnet is not a bad thing to take with You (not too strong)
PostPosted: Tue Apr 13, 2010 9:21 pm
Yup beat me to it John, i never look at any car without a fridge magnet in my pocket
 Post subject: Rust
PostPosted: Wed Apr 14, 2010 7:09 am
BTW. RUST IS USUALLY RED IN COLOUR !
"Let us remove your "SHORTS"
PostPosted: Wed Apr 14, 2010 8:41 am
check suspension towers from inside the engine bay too. under the carpets if you can and the battery box and spare wheel area
EDIT
also check where the windows slide along in their channels on the doors. and around the release button for them. also follow the lines for the washerbottle to the push button in the dash and check for rust along them.
1962 850,Frog
PostPosted: Thu Apr 15, 2010 6:56 am
from what i have seen on mini forums and my own mini. the worst areas are front floor, boot floor, battery box and valance panel. In saying that, the dreaded rust is not fussy.
Good luck on saturday
PostPosted: Fri Apr 16, 2010 3:38 am
And a 1 cm bubble is normally a 10 cm problem.
Users browsing this forum: Jim1965 and 316 guests
